- Relearn required? [solved]
- Rough idle, keeps dying
- Rough idle/ Misfiring p0300-p0304
- 2004 lx P0302,P0303
- 2002 Civic Manual Idling Rough/ Bogging
- Engine turning off
- 05 Civic surging RPM
- Cylinders misfiring/fuel pump problem
- Idle Surge and Cold Start only
- Hunting idle
- Stumbling/Missing after warm. No codes. Help! [solved]
- Idle Issue Caused By Cat Delete? (*FIXED*)
- Idle surge [solved]
- 2002 civic rough idle [solved]
- P0505 :(
- Idle stuck at 2000 rpm
- Hanging Idle 2001 EP2
- 2002 Honda Civic Ex Coupe Missfire in all cylinders and rough idle
- initial stalling driving issue
- '04 Civic fuel pressure regulator question
- Engine Misfiring and Stalling, What to Do? [solved]
- Multiple misfire at idle
- Rough idle on cold start
- Poor Idle [solved]
- slight low idle
- Idle @ 1500-2000 rpm after Cylinder Head work.
- Fluctuating idle.
- Need a straight answer!!! Please Help
- Rattling noise when idling or coming to stop
- How to clean throttle body on 02 si
- Running issues after exhaust header / cat change [solved]
- Idle issue
- Rattling Noise Near Engine - 2002 Honda Civic LX
- 02 civic lx TDC sensor
- IA Possibly causing TPS short?
- Alternator bad or IAC dirty?
- Rough idle after replacing fuel pump
- 2001 Civic - Surging Idle
- IACV cleaning
- Idle after warmup rpm & a/c, fans stall shaking issue
- IAT code P0113
- Electrical check of IACV
- Whining Noise during idle
- Low idle, pls help
- Misfire at cold start only.
- Rough idle
- A different Idle issue
- New Here. Rampant Idle
- Idle bounces after letting off throttle
- Squeaking noise coming from passenger side of engine bay
- 2003 Civic Hybrid stalls when in park
- Another Idle Issue help request :)
- 01 civic ex stalls while driving or idling too long (traffic)
- RPM issues
- 2005 Civic Hybrid -- surging / hunting idle issues
- 01 civic ex semi ruff idle
- Erratic idle problem
- Engine Races (4-5000 RPM) When First Started
- 2004 Honda Civic LX weird startup behavior when engine is hot
- 04 SI Hatchback Idle Problems
- 2001 civic ex idle issues
- honda civic 2003 idle at around 1.5k rpm
- D17a2 loss of power and rough idle
- Wandering Idle When Tank >1/4 Full
- erratic idle
- Rough idle when stopped, almost stalls when AC is on
- 02 Civic- Hunting Idle issues
- 2004 Civic KE (1.4) Idles at 2k
- Malfunction indicator light flashing/high idle issue
- 01 Civic D17A2 idles at 3500 RPM
- please help! idle problem.
- 2001 Civic Idle issue
- 2005 Civic O2 sensor & and surge
- idle surge 1000-3000RPM
- High rpm idle 2000rpm and p1753 (JDM d17 swap)
- Car Idle Problem 2002 Honda civic
- Idle after warm-up problems
- RPMs won't decrease
- If you have idle issues look here before posting!!!
- Idle Surge Solved!! Everyone Please Read!
- Rough Idle? I Got You Covered!!!
- HELP! strange rpm problems
- prob with idle
- help, car idling weird, gas mileage going down!!
- Stallin and low idle
