Idle Issues If you have idle issues, post here!
HELP! strange rpm problems
Old Jul 16, 2006
aeropast37's Avatar
aeropast37 is an unknown quantity at this point
Exclamation HELP! strange rpm problems
2002 civic ex coupe: I have a problem with my rpm gauge going up and down when I drive regularly...it also makes this clicking should behind the glove compartment too. It jerks my car and sometimes its so bad that it turns off the rpm gauge and cant really give it much gas...it usually happens when I park my car outside in the sun...but when I turn the AC to cool the inside the problem doesn’t happen... I've already tried changing the fuel pump relay but no change...I just don’t know what it is. Help me
Old Jul 16, 2006
clicking might be a bad relay. pull off the glove box and look around at those small black boxes. they might be sticking in the heat. if you try that and its still bad, might need to clean the idle air control system by taking off the throttle body and just cleaning off all the carbon, and doing the idle learn.
Old Jul 21, 2006
aeropast37's Avatar
are you sure?...i don't know what it is...i tried to clean the TB but it still happens...ive tried to change the fuel pump relay,air filter,spark plugs...it must be a electrical thing...any other ideas?it runs fine when i run the AC to cool down the inside
Wild Cranker
May 19, 2015 06:10 PM
mrcell24
May 19, 2015 10:02 AM
ywgflyer
May 15, 2015 05:05 PM
McD
Apr 16, 2015 10:46 AM
dooner24
Apr 14, 2015 07:51 PM
