Idle Issues If you have idle issues, post here!
02 Civic- Hunting Idle issues
Old Nov 10, 2015
Green02civic's Avatar
Green02civic is an unknown quantity at this point
Hey Guys,
I read the sticky about Idle issues, and im still scratching my head on this. I have a 02 civic SOHC.
about a month ago, I had a exhaust leak in an aftermarket stainless manifold. At the same time, I would have issues with the car starting. I had a CEL code of bad 02 sensors. I assumed the start issues were due to the manifold crack. Ordered a new manifold. I installed the new manifold. I had a leak. Upon further inspection, I recieved a faulty manifold. There were unfinished welds where the pipes meet the mount. So, I welded up my stock manifold, and stuck it on there. Still have the hunting idle after the idle learn procedure.
Bought new 02 sensors, and a new PCV, since I was getting error codes on these. Installed, no dice.
So, I checked the intake manifold and all vacuum lines for a leak, and I can't find one.
At this point, my only thought was it must me the TB, so I bought a used one off ebay. When It arrived I cleaned it really good, but left the TPS alone.
Installed, and here is where I am now...
IDle relearn procedure....
REmoved positive side battery cable for a few minutes, and reinstalled
3K until the fans kick on
Turn car off, remove positive cable again for a few minutes and install.
Turn car on and allow to idle.
I forgot to mention, that there is nothing electrical on inside the cabin. no radio or heat or anything.
For about 30 seconds I get an idle of 900 then It begins to hunt between 1100 and 2K
When I pull the car out of park, and into a gear, the idle drops to a steady 1100, but still way too high.
At this point, I am thinking that even thought I checked for vacuum leaks, I have one somewhere.
I do not have a CEL at the moment.
Any suggestions from the forum would be appreciated...
Old Nov 10, 2015
Mad Dog Tannen's Avatar
Re: 02 Civic- Hunting Idle issues
Idle air control valve may be bad. Run the meter on it
Old Nov 10, 2015
I'll check it out. I suppose it's possible that the iac is bad on both tb's.I'll let you know what I find.
Old Nov 10, 2015
IAC valve could be stuck open, tap on it?
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
What_It_Do
30
Nov 24, 2015 08:07 PM
NewHondaCivic
Nov 9, 2015 01:17 PM
chilling_pete
Nov 5, 2015 10:05 PM
98hondaciviclx
Oct 30, 2015 12:21 AM
