Idle Issues If you have idle issues, post here!
High rpm idle 2000rpm and p1753 (JDM d17 swap)
Old Jul 7, 2011
irochos101's Avatar
irochos101 is an unknown quantity at this point
Exclamation High rpm idle 2000rpm and p1753 (JDM d17 swap)
Hey guys the motor blew up in my 03 civic ex and I just replaced it with a jdm d17 just having a few problems. When I first crank up the car it will idle normally for about a minute then jumps up to 2000 rpms and holds. I've looked to see if i missed any vacuum hose connections or sensors but everything seems to be hooked up properly. There is a check engine light on it is (which causes the D4 light to blink):
P1753 Problem in Torque Converter Clutch Solenoid Valve Circuit
I'm not sure what could be causing this code to come up either. I haven't even put the wheels on to test drive it yet so i'm not sure if the transmission is acting funny or not. I took a video of the idle issue that I will have a link for below (Did not touch the gas pedal the entire video). Any suggestions would be greatly appreciated. Thanks in advance guys
Video link - http://youtu.be/80-GLFrOaek
Old Apr 15, 2016
Spooly329's Avatar
Spooly329 is an unknown quantity at this point
Re: High rpm idle 2000rpm and p1753 (JDM d17 swap)
I just did a D17 jdm engine swap myself and am getting the same P1753 code for the TCC A Failure. Did you ever get yours resolved? What was the fix for that code?
Thanks!
Old Apr 15, 2016
nomoneyracing's Avatar
nomoneyracing is an unknown quantity at this point
code 1753. follow upper radiator hose to engine, feel top of trans probably did not plug in tcc connector.
Wild Cranker
May 19, 2015 06:10 PM
vtechcivic
Apr 21, 2015 06:58 PM
Aznnp77
Dec 13, 2001 04:03 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
