Idle Issues If you have idle issues, post here!
Wandering Idle When Tank >1/4 Full
Old Apr 9, 2018
BrotatoChip's Avatar
Super Moderator
I discovered something really weird yesterday (2001 Civic EX). The idle was all over the place once warmed up so I replaced the IAC, this seemed to mostly fix the issue. When I slowed down for a stop sign though the idle would jump up to ~1500 rpm then drop to ~1000, then back up to ~1500, and finally drop to normal idle. I though maybe there was some air in the system still, I also had the loss of power issue discussed in another thread so I ignored the idle. While replacing the fuel filter/strainer I emptied the fuel tank down to about 1/4 tank. Afterwards I took the car for a 20 mile drive, no loss of power and the idle seemed to fix itself (no more wandering at stop signs).
Well yesterday I put a few gallons of gas in bringing it up to just shy of half a tank and the idle issue immediately appeared again as I was leaving the gas station, coincidence?? I really don't know what to make of that. The IAC I used came off another Civic that didn't have any idle problems but it had been sitting for a few months. I guess my next step would be pull it back off and try to clean it real well. Any other ideas?
Old Apr 9, 2018
Slumpertcivic's Avatar
Re: Wandering Idle When Tank >1/4 Full
The fuel pump, and evap system would be the only things affected by opening up the fuel tank and adding gas.
Being that you just took apart and replaced parts on your fuel pump I would suggest getting actual fuel pressure readings before replacing anymore parts.
Old Apr 9, 2018
Super Moderator
One thing I should mention, when I had the gas fill cap off I noticed the rubber seal on it was broken. I swapped a known good cap on before I left for work this morning.
Nixter
Aug 29, 2016 06:23 PM
maxtierney
Jun 20, 2011 09:10 PM
leuch3rd
Oct 28, 2009 12:53 AM
xDCx
Jan 26, 2005 12:52 PM
