Idle Issues If you have idle issues, post here!
Relearn required? [solved]
Old Dec 28, 2024
RayS's Avatar
RayS is an unknown quantity at this point
Hi, I've recently replaced the intake gasket on my D17 to correct a recurring EGR code. While I was in there, I replaced all four injectors with new ones that were advertised as being OEM Honda. There is some intermittent hesitation and stumbling now when driving. Is this expected as part of a relearn process? Thanks.
Old Dec 28, 2024
betdriver01's Avatar
betdriver01 is an unknown quantity at this point
re: Relearn required? [solved]
i got similar problem here. after clean and replacing E.G.R. and I.A.C. valve gaskets the car still vibrating like before and die at a stop light or while idling. now when i went to Oreillys for second time, they say is cylinder #2 spark plug because the misfiring condition. i did it and no change at all.
Old Dec 28, 2024
Colin42's Avatar
Wouldn't hurt to try. Did you use the intake gasket with the egr holes? Did you clean the passages in the intake?
Old Dec 28, 2024
RayS's Avatar
I did. I found the thread on this forum and sure enough, the wrong gasket was on the car. I put in the one with the holes and cleaned the passages pretty thoroughly. I may end up swapping the old injectors back in to see if that fixes it.
Old Dec 29, 2024
RayS's Avatar
Well, it finally gave me a CEL, which turns out to be a P0172. I probably didn't plug a hose back in properly. Will update when resolved.
Old Jan 4, 2025
RayS's Avatar
I was able to find the issue. Pulled the plugs and all 4 indicated they were running rich. I replaced the new injectors with the old ones, and that did the trick. Runs like a sewing machine now. 🙂
Cranium1814
Jan 12, 2023 12:49 AM
redderm
Sep 23, 2017 12:07 AM
mattandchris
Sep 19, 2012 01:24 AM
garageman402
Apr 26, 2007 09:18 AM
smartblue
Apr 27, 2004 11:03 PM
