Idle Issues If you have idle issues, post here!
please help! idle problem.
Old Mar 9, 2015
em2-ed's Avatar
em2-ed is an unknown quantity at this point
Hello ! Im looking for some feedback as to fixing my problem.
I have a 2003 honda civic ex 5mt all stock. It has about 237k miles on it and recently replaced the exhaust flange gasket. After i replaced it, the car ran fine for about 10 to 15 minutes on the road but then idle roughly then died. I disconnected the battery which helped so i could make it home . When in neutral it doesnt stall but when i drive and come to a stop it does. It also makes a loud noise similar to a pop . All this never happened before replacing the exhaust flange gasket. I think it might be a bad gasket seal since these problems did occur after fixing them but i want some feedback first!
Old Mar 9, 2015
mikey1's Avatar
Re: please help! idle problem.
i guess common sense would be to check your work
bolts loose?
is it leaking exhaust around the gasket?
check engine light on?
Old Mar 9, 2015
em2-ed's Avatar
bolts loose?
The bolts are tight. It was lleaking from the exhaust flange gasket, but i placed the new one. No check engine light. Im reading that maybe i need to reset my idle hopefully this works.
Old Mar 9, 2015
Honda 735's Avatar
Honda rebilder
Honda 735 is an unknown quantity at this point
Check your idle control valve. The aluminum usually gets corroded. Replace it.
Old Mar 10, 2015
lowlife9's Avatar
did you replace the spring bolts ???
Old Mar 10, 2015
em2-ed's Avatar
Im going to inspect and clean it first , never had a problem with it before the gasket replacement.
Old Mar 10, 2015
em2-ed's Avatar
No i didn't. It sounds like a good idea though, maybe get a better seal. I have tried to relearn idle and it has ran better with less stalls but there is still misfires when driving. Runs really shitty.
Old Mar 11, 2015
mikey1's Avatar
i already asked you if it was leaking,
it either is, or it is not....which is it?
Old Mar 11, 2015
madcivic's Avatar
madcivic is an unknown quantity at this point
Hi guys sorry for changing the topic just Lil bit I'm having the same issues but my case is that I got a mini swap a ZC block with a D16Z6 head, it started just fine but it die after 2min, no wier noises or nocks I tried to turn it back on but it wouldn't start at al, I can only hear the engine spinning. I already double checked everything spark fuel timing etc and their fine but when I tried to start the car with starter fluid the intake won't even suck the fliud!!! What can cause this weak air suction issue??
Please any help is well welcome
Old Mar 15, 2015
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
Does your exhaust have an oxygen sensor, usually has 2 small wires running out of it that go to ECU? The wires could be lose, broken or the sensor bad. Have you changed your plug wires in the last 100K miles?
SimpleUser
Apr 24, 2021 02:54 AM
Martinez8o5
Jul 31, 2015 10:58 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
cgavin1
Jul 7, 2015 07:10 AM
