Idle Issues If you have idle issues, post here!
Rattling noise when idling or coming to stop
Old Aug 17, 2021
Blackbird307's Avatar
Blackbird307 is an unknown quantity at this point
Hello all,
I have a 2003 Honda Civic LX with a 1.7l engine. When I am idling sometimes I hear a fast rattling/ticking noise, but not always, seems to be on or off. However when I turn the wheels full lock the sound returns. When I come to a hard stop the noise comes back as I am stopping.
Does anyone know what could cause this? Thanks!
Old Aug 17, 2021
BrotatoChip's Avatar
Super Moderator
Re: Rattling noise when idling or coming to stop
I would guess an exhaust heat shield is loose and rattling.
Old Aug 17, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Or front brake rotor dust shields came loose from corrosion.
Old Aug 17, 2021
Yeah when I crank steering full lock (putting a load on engine using power steering pump) it makes a ticking noise, sounds like it’s coming from valve cover area. Bad sign.
no loss of power though, drives fine too.
Old Aug 21, 2021
open hood and start inspecting. Screwdriver works as stetoscope
Old Oct 28, 2021
Senditdude's Avatar
Sendit
Senditdude is an unknown quantity at this point
I had the same symptoms hear recently. Might not be the same cause though. Mine ended up being the air cleaner not being tightened all the way
mkokotovich
Aug 26, 2011 07:16 PM
vicfirth182
Jan 17, 2010 12:21 PM
speedracersong
15
Sep 26, 2007 12:07 PM
pheaton
Mar 8, 2004 01:46 AM
nongv
Sep 20, 2002 05:13 PM
