weird engine noise
weird engine noise
hey guys. so when I am running about 2700 or so rpms I get a weird knocking sound in the front end. it kinda sounds like a train noise or somthing. it only makes the noise at that exact rpms. could it be the belts flapping aroubd or somthing?
Re: weird engine noise
its very common, like a rattle sound. i get it all the time too around same rpms. i think its just valve noise cause when i rev it in N with the hood open, i can hear it coming from inside the engine.
Is it a metallic rattle or squeaking noise? If so, put the front end on stands and carefully inspect all of the exhaust heat shields for looseness or cracks.
When I had heat shield noise, it also only happened during acceleration around the rpm range you mention. Turned out to be a hairline crack near one of the shield attachment bolts.
mrohitredd
18
May 14, 2015 07:35 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
