Alternator
Old Jan 15, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
Alternator
sup everyone
I checked the battery voltage while the car is on its 12.6v or less.
When I drive it it makes a loud whining noise. not from the stereo..i can hear it coming from the engine bay. The battery light is not on.
You guys think i got a bad alternator? i have checked all fuses.
I might drive it to autozone and check
Old Jan 15, 2010
Re: Alternator
yeah just have it checked. our alternators are tricky, cause there is a load detector that turns it off when power isnt needed. have someone turn the fan **** from off to full while you check battery voltage with the car running. or turn the a/c on. something that draws alot of power and will cause the eld to turn the alternator on full power.
Old Jan 15, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Alternator
The voltage across the battery posts should be around 14V or a little higher. Clean and tighten the battery terminals and the ground wire connection. Have you checked whether the alternator belt is tight? Any electrical problems?
Old Jan 16, 2010
Re: Alternator
Yeah its a new belt. i did a auto to manual swap so i bought all new belts.
No electrical problems as of now. Just my speed sensor isnt working. i dont know what wires to cut
Old Jan 16, 2010
RonJ's Avatar
Re: Alternator
What year Civic? If it is 96-00, check whether 7.5A fuse 15 under the dash is blown.
If you have a 7th gen Civic, check 10A fuse 4 under the dash.
Old Jan 16, 2010
Re: Alternator
Already checked it..
thats weird the alternator worked before we did the swap...you have any idea what the whinning noise is? its coming from the engine bay. not from the speakers
Old Jan 16, 2010
RonJ's Avatar
Re: Alternator
Pinpoint the noise using an inexpensive engine stethoscope.
You'll generally get more specific information by mentioning the year/trim Civic.
Old Jan 16, 2010
Re: Alternator
oh yeah sorry its a 02 civic ex
Old Jan 17, 2010
Re: Alternator
Brought it to autozone they said it was bad
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
