Idle Issues If you have idle issues, post here!
A different Idle issue
Old Oct 18, 2019
KiwiCivicDriver's Avatar
KiwiCivicDriver is an unknown quantity at this point
Question A different Idle issue
Hi Guys I've been through and cant find this issue, I've done the idle reset process and that has not helped.
However I had erratic idle and replaced the Idle control valve now the idle is smooth and stable EXCEPT: after I come of the gas the idle sits at about 2K and stays there until the car comes to a rest (Complete stop) then the idle stays high for a few seconds then drops to 700 and stays there.
It does not matter if the car is rolling even a couple of KMpH out of gear (manual) the idle stays high until a dead stop is reached.
Thoughts?
Old Oct 18, 2019
Colin42's Avatar
Re: A different Idle issue
Did you use an OEM IAC?
Old Oct 18, 2019
No, I used an after market one. It works in all other respects. And the fact that the car rolling seems to have an effect make me think its some sort of speed sensor issue ..??...
Old Oct 18, 2019
GolNat's Avatar
Prelude Owner
A good read:
https://www.civicforums.com/forums/3...ent-surge.html
TL;DR Used an aftermarket IACV and it gave him problems.
Old Oct 18, 2019
Colin42's Avatar
Honda's are picky when it comes to electronics, grab an OEM one from a junkyard, give it a good clean and try that. Will be cheaper than a new oem
Old Oct 20, 2019
Ill; give that a try. yes I was quoted hundreds of dollars from the Stealership for one. The aftermarket one is much more affordable.
Old Oct 20, 2019
Colin42's Avatar
But if it doesn't work then it's not more affordable, it's throwing away money
Old Oct 20, 2019
GolNat's Avatar
Prelude Owner
Try an online dealer. Can save as much as 20% compared to local dealers. Majestic Honda or Honda Parts Cheap. Junk yard is a good option also.
Like Colin said Honda's are particular about electronics. They like OEM parts as most modern cars seem to prefer.
Old Oct 20, 2019
Obviously... ... Bugger.
Old Oct 20, 2019
Ill have to hunt around online and in person guess.
The one thing I don't get and would love some thoughts on is that the car seems to know it is rolling (out of gear) and keeps the idle high until it stops then drops it.
Is there a speed sensor and circuit that may be contributing?
Note: never seen an engine check light other when starting the car.
tunedx
Sep 23, 2014 07:02 PM
jobu123
Jun 20, 2013 08:51 PM
Radjin
May 1, 2012 06:18 PM
CivicHeadd
Jun 26, 2011 11:39 PM
finkenator9
Apr 20, 2010 09:26 PM
