Idle Issues If you have idle issues, post here!
Rough idle
Old Oct 27, 2019
James Tyler's Avatar
James Tyler is an unknown quantity at this point
Rough idle
Hi! I have an 05 Civic DX, recently replaced clutch and have developed a VERY rough idle. I have done a idle relearn procedure to no avail. Just wondering if someone had any thoughts or suggestions to offer. Thanks in advance.
Old Oct 27, 2019
Colin42's Avatar
Re: Rough idle
Did you forget to plug something back in? Anything get bumped or damaged?
Old Oct 28, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Rough idle
Exedy clutch kits are recommended by many and either re-surface their stock flywheel, get another OEM Honda flywheel, or buy a high quality light flywheel.
Change your oil after if your flywheel is off balance.
Old Oct 28, 2019
GolNat's Avatar
Prelude Owner
Re: Rough idle
Engine/trans mount not tight?
Old Nov 1, 2019
Marcelo Souza's Avatar
Marcelo Souza is an unknown quantity at this point
Re: Rough idle
depending on if the clutch is aftermarket or not it might be heavier you need to raise the idle a little bit, on the throttle body where the throttle cables Lead too there is is a 7mm bolt that is on a screw that needs a hex key to turn, it controls the idle speed I have stage 2 cam for it and had to raise my idle speed so it wouldn’t bog. If the car is not modified you will have to remove the whole air box assembly to get to it
KiwiCivicDriver
Idle Issues
Oct 20, 2019 09:41 PM
Radjin
May 1, 2012 06:18 PM
tchongtching
Jun 10, 2009 01:49 PM
tweeder
Sep 3, 2006 05:32 PM
2K1Civic17"Gabe
Apr 7, 2005 01:51 PM
