Sweeping Idle
Old Sep 3, 2006
tweeder's Avatar
tweeder will become famous soon enough
Sweeping Idle
Ok so I took my 01 ex to the shop and tell them that something is f'ed in my tranny, the told me since I had an aftermarket clutch to go to hell so...
I ripped everything open found that the input shaft bearing was messed up changed that out. Put on a header, downpipe, replaced the friction plate on my Fidanza aluminum flywheel, swapped my exedy stage 1 clutch with a Fidanza 3.2, ported and polished the head, lapped in new valves, swapped in a d17a1 bottom end (had it laying around, only 9k on it), and threw on crossdrilled and slotted rotors with ebc Redstuff's.
So after all of that I start the car and my idle sweeps from about 1600 to 2700 rpm's any ideas?
Old Sep 3, 2006
sounds like a problem with the throttle body tps sensor. did you do anything to that? what about ecu reset and idle learn?
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
pfwel1977
Sep 10, 2015 02:16 PM
Bricoleur
Sep 9, 2015 12:23 PM
