Idle Issues If you have idle issues, post here!
RPMs won't decrease
Old Apr 5, 2011
gpaas's Avatar
gpaas is an unknown quantity at this point
RPMs won't decrease
Hi everyone, I'm new here and have had my 02 Civic EX for about 6 months now. I have come here for some good advice but now I need some help.
I was just out driving and my revs would not decrease. I didn't think much of it at first (could be just warming up longer than usual) but then I noticed I could just coast in gear and the tach would not go down. I tried pressing the gas and it started revving up near the redline and would not go down. I quickly turned the engine off. I checked the throttle (my first guess) but it seemed fine, so I turned it on again and the problem persisted. The check engine light came on. I can drive it - I drove down a few neighbourhood streets and and home again - but it's worrisome. Especially when it shot up near 6000 rpm and I couldn't do anything other than shut it off. It stays around 2500 rpm if it's just idling.
Any help would be appreciated. Thanks so much.
Old Apr 5, 2011
Re: RPMs won't decrease
are the revs actually going that high from what you can hear? or is it just the gauge reading high. if its the engine revving, you prolly have a bad TPS (throttle position sensor) which pretty much tells the ecu how much you are pressing the gas pedal. check the engine code to be sure. if it is, youll need another throttle body. used ones on ebay are around $50 for the whole thing and you can just swap it in with all the sensors on it. make sure you get the correct version depending if you have manual or auto trans. it matters.
Old Apr 6, 2011
thewal's Avatar
thewal will become famous soon enough
Like gearbox said Throttle body. Do you have access to a scan code reader, try and et the code.
Jul 12, 2015 11:54 AM
beeemerdude
Jul 10, 2015 09:22 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
