PDA
View Full Version : Engine
  1. Camshaft/ Crankshaft sensor
  2. Possible boost leak?
  3. sensors
  4. Colour code for crankshaft bearings?
  5. 21 Honda civic sluggish
  6. No start/ Intermittent starting
  7. Misfire cylinder #2 p0302
  8. Honda Civic 2017 1.0L CVT
  9. I have been having carbon buildup with the GDI system. Need advice
  10. Starter or Ground Cable
  11. Throttle Sensor Position Ground Location
  12. 2021 civic cold start issue ?
  13. Went to start my car and it just turns over.headlightsflash intermittently
  14. 2017 Civic Cranks up and cuts right back off
  15. civic exhaust noise?
  16. Engine problems 2017 Civic 1.0
  17. Replaced catalytic converter [not a problem, recommendation]
  18. Custom intercooler [solved]
  19. cracked oil pan - 2019 civic sport (10th) gen
  20. 2018 Honda Civic Si
  21. What are these codes
  22. Daughter ripped off bottom on 17 civic
  23. No start, single click
  24. Engine noise
  25. Replace Fuel Filler neck seal
  26. Need to find a stock air intake system for '21 Type R
  27. 2019 Si - Intermittent misfire when accelerating but smoothes out.
  28. Emissions System Problem 2016 EX 2.0 Sedan
  29. Need Recommendation Brandon/Tampa to replace engine and turbo assembly 1.5L
  30. Rough engine in colder weather
  31. Help with part name
  32. Engine braking noise when I let off the throttle and coast
  33. Engine starting slower than normal
  34. 2019 Turbo 1 low revs noise.
  35. Hesitation at 4k
  36. P0344 error issue in bank A
  37. Bad Startup
  38. Boggs out when turning
  39. hydrolocked? Did i just lost my car?!?! >_< [solved - yes]
  40. What Timing Belt "Part Number" in 1.0L engine?
  41. Intercooler Pipes collapsing
  42. P2623 Injector Control Pressure Regulator Circuit/Open on Honda Civic 1.5L Turbo
  43. Coolant Change issue
  44. Car smells like gas after filling up my tank
  45. Check engine light flashes and won’t go over 15 mph
  46. coolant drain plug location for 2020 Honda Civic LX [solved]
  47. Localização Filtro de Gasóleo Honda Civic G10 1.6DTEC 2019
  48. EGR readings
  49. Stuck Gas Door Latch/Fuel Mileage 2018 Honda Civic
  50. 2018 Civic Si smoke coming from front end
  51. FK7 2019 CVT - Damaged hose on engine
  52. Car Wont Start some times
  53. 2016 EX - Water pump replacement
  54. 2016 Honda Civic sputters and throws misfire codes.
  55. Honda Civic Feels Sluggish after oil & fuel filter change
  56. 10th gen rattling and grinding noise from the engine when the gas pedal is pressed h
  57. Engine Rattle
  58. fueled while running
  59. Horrible (23-26) mpg? 2019 Honda Civic EX-L
  60. Valve Lash Check
  61. Water Pump Replacement
  62. Mileage
  63. RPM fluctuation and acceleration
  64. Unable to fill fuel tank
  65. 2018 limp mode after dealer wire repair and new throttle body and app sensor
  66. Fuel Leak?
  67. Issues Starting 2017 Civic in Cold Weather
  68. oxygen sensor
  69. Muffler Nuts welded to the exhaust bolt?
  70. 2016 deeper sound when accelerating
  71. Rats eating cables
  72. 2018 Civic EX-T Cat
  73. 2019/2020 HONDA CIVIC STARTS for 2-3SECS then cuts off
  74. Engine sounds like gasping/ belt sounds weak
  75. 2016 Civic EX-T
  76. Honda Type R fk8 noise in engine area
  77. 2020 civic hatchback 1.5T high rev +5000 RPM on its own
  78. is my alternator dying or my battery on my low mileage 2016 civic?
  79. Civic Hatchback 2018 how to unscrew engine filter bolt???
  80. 2020 Civic rough idle
  81. Engine Wire Harness: Rodent Damage to Harness
  82. Gas mileage dropping significantly
  83. 2017 civic 1.5l thermostat
  84. 2017 hatchback sport, fuel guzzler?
  85. Serpentine belt replacement
  86. Car jerks at certain times
  87. Oil leak !!!
  88. Engine making weird sound
  89. Car would not re-start after accidentally turning off ignition with car in neutral.
  90. Civic 1.0 P10A2 Engine Problem
  91. Anyone Know The Tolerance For Serpentine Belt Length? (2017 EX - non-turbo)
  92. High knock control
  93. 2019 Honda Civic LX Emissions System Problem
  94. 2017 civic turbo goes into limp mode
  95. louder acceleration
