Rough engine in colder weather
Old Oct 19, 2023
Daytripper49's Avatar
Daytripper49 is an unknown quantity at this point
I have a Honda Civic 2009. When the weather below 50°, the engine runs noticeably rougher and takes longer to “warm-up “. It is definitely related to the temperature, as there are no problems in warm weather. Nobody seems to know the reason why this is. Any suggestions?
Old Oct 19, 2023
BrotatoChip's Avatar
Super Moderator
Re: Rough engine in colder weather
How is it rougher? It's a small engine, it's going to take some driving to get it warm.
Old Oct 19, 2023
It actually makes the car vibrate noticeably.
Old Oct 19, 2023
Colin42's Avatar
Check engine light?
bad coolant temp sensor maybe? Checked filters? Sparkplugs? Bad gas?
Old Oct 20, 2023
Originally Posted by Colin42
Check engine light?
None of the above with the possible exception of a bad coolant temp sensor. Is it easy to replace?
Old Oct 20, 2023
Colin42's Avatar
It's fairly simple, make sure you buy an oem one. Aftermarket ones never seem to work properly. I would check the temp readings with a scanner to see if they look weird before throwing parts at it
Old Oct 20, 2023
Many thanks
stonedrives
Jan 28, 2022 01:29 AM
New2Driving
Detailing
Dec 24, 2020 08:01 PM
kharris
Sep 30, 2011 01:12 PM
Ashhole
Nov 22, 2005 07:57 PM
ZSKCivic01
May 29, 2004 10:27 PM
