2016 Honda Civic sputters and throws misfire codes.
Old Apr 20, 2022
Aubrey0611's Avatar
Aubrey0611 is an unknown quantity at this point
My 2016 Honda Civic sputters and throws misfire codes for cylinders 13 and four it was two, three and four. I get a mission systems problem light pops up also brake system and no power to the steering control pops up as well.It idle smoothly and park but shakes real rough if I go in reverse neutral or drive and it will not go above 2500 RPMs. I’ve changed all my spark plugs all my coil packs look good I tried a whole new tank a gas and also a oil change
Old Apr 20, 2022
Re: 2016 Honda Civic sputters and throws misfire codes.
too many codes, usually linked to battery or charging system - any parts store can check them, do that first and check 1 item out of the list
electronics hate voltage/amperage fluctuations and lights a Christmas tree in the dash
Old Apr 20, 2022
Aubrey0611's Avatar
Even if it only shakes in reverse and drive? It is calm and normal in park and neutral
Old Apr 20, 2022
you have a lot of codes regardless, solving them is first priority, car is asking for help on them
Old Apr 20, 2022
if after solving the codes, you still have issues, come back, or you can keep us up-to-date
Old Apr 20, 2022
Aubrey0611's Avatar
Yeah I know I definitely do, I just put in a new battery right now and it’s all the same steel. PS none of this started happening until yesterday and I even get a no power steering light and I know my power steering is fine so it’s really just something causing all these lights to come on at once
Old Apr 20, 2022
OK, do you have a battery charger?
If yes, charge it overnight. Batteries are never fully charged at first (drops in storage).
if still issues, then solve issues one by one.
there's still the issue if charging is working or not
you can also take car for diagnosis - if anything sounds suspicious, you don't need to have them done and come back for advice
Old Apr 20, 2022
Aubrey0611's Avatar
OK thank you so much I will try charging it tonight, and I’m having a diagnostic for tomorrow during lunch
Old Apr 21, 2022
BrotatoChip's Avatar
Super Moderator
We've seen chewed up wiring from rodents in the engine bay. Not sure if your symptoms are the same but worth a check.
Old Apr 22, 2022
did charging it help?
Did they find anything wrong?
Old Apr 22, 2022
Aubrey0611's Avatar
barging didn’t help and both mechanics said coil pack which I already changed and then they were at a loss which shocked me
Old Apr 22, 2022
so engine issues continues, do the brake/steering alarms still appear?
SpeedReeeser516
Nov 5, 2019 08:44 PM
oXoreoXo
Feb 6, 2017 02:00 PM
kevin98208
18
Jan 4, 2017 08:10 PM
stHcivic02
Apr 1, 2014 02:54 PM
