cracked oil pan - 2019 civic sport (10th) gen
Old Jun 8, 2024
Offshore's Avatar
Offshore is an unknown quantity at this point
Just bought a civic sport sedan with a cracked oil pan. Did not notice it until the tow truck drivers delivered it a few days ago. How severe can this problem be? Am I definitely going to need a new motor?
Old Jun 8, 2024
re: cracked oil pan - 2019 civic sport (10th) gen
How bad is the crack? Was it causing you to lose oil? If so, how low did the level get before you discovered it? If it's just the oil pan and there was a good amount of oil in there, you should be able to replace just the pan without other issues. You'll want to inspect the block to make sure there's no additional damage.
thing's pretty pricey new though, so see if any local junkyards have any non-turbo 10thgens and grab one from there.
https://www.hondaautomotiveparts.com...bC1sNC1nYXM%3D
You'll also need a tube of HondaBond (or other oil pan gasket RTV) since that's what's used as the oil pan gasket.
PilotTerry
General
Jul 13, 2025 06:20 PM
rhvic
Jul 2, 2020 06:50 PM
Niaboc67
24
Aug 5, 2017 11:05 PM
midnightblueEX
19
Jul 25, 2005 12:35 PM
