Cracked cylinder head, cracked cylinder wall, or cracked block?
Hello,
I have 150k on my 03 Civic it has overheated several times. I thought I had a blown head gasket turns out I do not. I pulled the car apart and pulled off the cylinder head. I took it to a machine shop and they checked it for flatness I got an okay from the machinist. I was told that if it was a cracked head that one of the cylinders would be steam cleaned. Nothing of the sort here. I am now left perplexed, what else could cause an overheating issue. I've had the water pump, stat, rad and fans checked and replaced. Two master techs suspected a small crack in the head gasket. Should i get a second opinion on the cylinder headbeing cracked? How about a cracked cylinder wall or a cracked block? How might one check for such things, such as tests. I poured blue devil engine sealant in this car before and it was a huge mistake. When I pulled off the head there was what looked to be white rock salt all in the cooling jackets and coolant holes. I got a lot of that out but not sure how to get the rest that must be in the cooling system. I pulled a big chunk of the sealant that was blocking up the thermostat. Before the sealant was put in the car, the car could run for an hour on the highway before overheating after the sealant it would run for a few minutes and overheat. This is probably due to the thermostat being completely blocked off by sealant. Here are pictures of the head gasket, the cylinder head, and the block.
https://m.imgur.com/a/5c4u4
Thank you
Thank you
Re: Cracked cylinder head, cracked cylinder wall, or cracked block?
With all that build up in coolant passages and what your describing as chunks you pulled out... the radiator and heater core are most likely clogged..
I assume you made sure thermostat in correctly, fans working, etc.
Your pics of headgasket aren't good for me to see. There's a lot of scuffing on that cylinder head surface as well its hard to tell how deep those are.. are these pics after head removed or after resurfaced?
the head has not been resurfaced the machinist seemed to think the head was okay. When the car gets hot and I turn on the air hot, I get full heat, wouldn't the entail that the heater core is working correctly?
1. Fans work fine, ive done the paper clip trick to short the fans and they both come on. Car still overheats just slower.
2. When I took the head off I also examined the stat housing, it was clogged with the blue devil sealant blocking flow. This was the reason for poor flow to the stat. So I need to thoroughly clean out all the passage ways that may have this sealant in it. Any ideas are welcomed and where else that might need to be cleaned.
3. With the rad. I removed the top and lower hoses, then stuck a garden hose to the top hose, I checked the flow of water. All seemed well, flow was consistent.
4. I did a compression check on each cylinder, for each one I got between 150-180psi. Did this both on a hot and cold engine.
5. Head gasket was replaced and I also removed the new old. I have both the new and old gasket in hand, both have both cracks haven't felt very carefully around the surfaces. Also took the head gaskets to a machinist who said there was also no cracks. Same with the cylinder head. Was checked with a flat edge and a flashlight. Nothing out if place.
Also with the heater core, when the car gets hot the and I turn on the air it is very hot so I guess this means the heater core is in working condition.
You won't because there aren't any cracks. It's still a gasket failure if it's a failure.
Usually the only outwardly visible clue is the black coating peeled off in a spot at the fire ring on the affected cylinder(s).
You did do the cylinder pressurization test to determine which cylinder(s) were breached, right? So you know which hole(s) in the head gasket to be inspecting.
Also, all those fine scratchmarks all over the important surfaces might be sufficient to cause problems (leaks) if you put it back together.
(I can't really knock this, it sounds like something I might do.....because it's easy to verify perfectly flat this way, but you can't measure the warp if it is warped.)
He was quite hasty about it, just slid a straight edge across it quickly and a flashlight. Seems like he could have been more thorough. Am getting a second shop yo be more thorough tomorrow afternoon. They will hot tank the cylinder head and check for any warpage.
That answers one issue.
Fire is cleansing
Sounds bad to me, too much variation if that's on one engine. But I don't see actual test results here to make that evaluation.
How many thousandths of an inch is that? Or how many hundredths of a millimeter is that?
That and the radiator seem ok I guess, but try to backflush to get any crud out anyway
Fire is cleansing
Am going to get a second opinion tomorrow at another machine shop. Do the pictures given provide any indication of any cracks it problems?
When I took the head from my civic to the machine shop they guy checked it. It was all fine until he measured diagonally that's where there was warpage between cylinders 2 and 3. When i looked at the gasket it was just missing the black coating like Ezone said, that was enough for a breach and coolant to go out the overflow.
You would see any cracks yourself better than any of us here on the internet.
I already mentioned:
The head and block machined surface finish must be extremely smooth so the head gasket can seal well, and sandpaper or whatever you used might have made it too rough.
If you had done the tests you would know which cylinder(s) you need to be checking.
Also, how likely are these heads to crack? Also, given that the cylinders look like there aren't steam cleaned, wouldn't this indicate that there isn't a breach in the gasket or a crack in the head. If there was a crack in either the head or gasket wouldn't there be clean signs or wear or steam cleaning? I see none of that, nor is there a milky oil or white smoke out the exhaust. The sealant was causing such a quick overheat but not the original cause before, of course. Would hope the head just needs to be resurfaced. But it seems like a cylinder(s) would be steam cleaned.
Block is thicker and less likely to crack or warp but still a possibility. Check out these pics: https://www.google.com/search?q=hond...w=1366&bih=623
Here's a read on cracked block symptoms: http://www.discountrebuiltengines.co...gine-block.php
I don't have enough experience with 7th gens to know if block cracks are somewhat common or an anomaly. Did you use a precision straight edge and feeler gauges to check the block for warpage?
As far the cylinder head any decent machinist will advise you to allow them to hot tank it to check for cracks, check it for level and check for valve leaks. What fee they charge is up to you to inquire about. A block could have a crack in the cylinder walls that may not be seen without the pistons removed. Do a wet compression test with a teaspoon of oil in the cylinders and see if compression rises.
From that link the only symptom I have is the overheating. It is a slow overheat that only happens after an hour drive. Doesn't seem to be a leak either. I see coolant be shot out the overflow after the drive. So something is causing a lot of pressure buildup. Seems like a head gasket or cylinder head crack would cause such a such problem. A breach would be gases are escaping and overheating the coolant so the car is no able to cool down the coolant fast enough and sends all that pressure to the overflow. That's what it seems like.
Get cylinder head inspected for cracks, valve leaks, flatness, compression springs tested. Check block for flatness as I mentioned previously. Inspect block and head for glass-like smoothness as Ezone asked you to do. If all is good install head per service manual. Use OEM head gasket only.
More reading on block crack inspection: http://www.enginebuildermag.com/2012...nd-correction/
basically, without it pulled from the engine bay and proper test equipment it may be all but impossible to find a crack unless you get lucky and it's located where it can easily be seen.
I want to be able to get all the blue devil contaminants out though.
Not impossible--- but not bloody effing likely especially if it really isn't warped.
You only get steam cleaning if water/coolant gets into a HOT cylinder -----while the engine is running.
A cooling system might reach a maximum 15 PSI.
Combustion pressures can be as high as 1000 PSI.
Which of the above is more likely to leak which direction---through a compromise that's in the 0.00001" range?
I always seem to get these type of mechanics who are very brief and quick with me, I wish I knew why they always act this way around me. Or maybe it's with everybody.
For the block what would you recommend for cleaning the surface,
I only use a single edge razor blade to scrape the high spots, and brake or carb cleaner to wipe it.
The gasket will always leave some black stuff embedded in the machined surfaces. I don't ever try to get the surface spotless.....because it's too easy to ruin the surface. FLAT is important, not spotless.
A breach would be
You've apparently got a combination of causes......
ONE was the glob of Satans Blue Goo blocking coolant flow.
TWO is the head gasket breach and all the associated symptoms that go with it
What I can't determine (and it's late I'm tired so I don't really care anymore) at this point, is, "which problem came first?"
