PDA
View Full Version : Hybrid Engine/IMA battery system
  1. Doing HG on 1.3L. What are these discs?
  2. How much power is in the Hybrid battery?
  3. 03 Civic Hybrid IMA just replaced. 12v light and IMA light still on
  4. HCH mods?
  5. Anyone ever own a Civic that threw error codes even if the CEL wasn't on?
  6. 2003 Honda civic went to replace a sensor but it is not there.
  7. 2003 Honda civic hybrid jerking while driving from a stand still
  8. 2005 Civic Hybrid not starting
  9. Help with Honda Civic IMA executive 2003 adjusting parameters
  10. Daisy chaining a dozen 12V AGM batteries to "fix" a bad IMA pack?
  11. Transmission fluid too full and "shudder" when taking off?
  12. 2003 HCH with suspected knock
  13. IMA battery passed voltage test? [solved]
  14. P1554/6/8 Battery Module Temp Sensors
  15. Drive Without Electronic Assist Battery? [solved]
  16. Cold air intake
  17. 2004 Civic Hybrid IMA Battery
  18. getting a 2004 civic hybrid through emissions [solved]
  19. Getting 12v in the trunk of 03 HCH
  20. Check items for 7th gen Hybrid not charging
  21. Battery Light comes on at idle
  22. 04 1.3L common oil leaks??
  23. 2004 Honda Civic hybrid no crank no start
  24. Help with IMA, 12 volt problems
  25. How to tell which catalytic converter is bad
  26. 2004 civic Hybrid P1432
  27. 05 Honda Civic Hybrid Odd Electrical Issue
  28. grid charger questions
  29. 2005 Hybrid Tranny #3 (2 Repairs)
  30. Should I buy this 03 Civic Hybrid for $4500?
  31. Oil leak mystery. It's all over the bottom of the pan.
  32. 2003 Civic Hybrid - Engine Vibration and Engine Mounts
  33. 2005 Hybrid Engine and IMA rebuild
  34. 03 hybrid weird steering issue
  35. Civic Hybrid Shift Cables?
  36. 04 Civic Hybrid Converter to Pipe- Need new gasket
  37. honda civic hybird 2004 hv battery add water
  38. Air Fuel Sensor for Honda Civic Hybrid
  39. Noise from assist motor?
  40. MPG
  41. Radiator cooling fans
  42. R&R serpentine belt, '03 Hybrid?
  43. Honda Civic Hybrid 2002 getting mileage data via ODBII
  44. General information on 7th gen Civic Hybrid
  45. 03 Hybrid Thermostat Removal
  46. Honda Civic Hybrid transmission won't move the car
  47. IMA Battery balancing
  48. What kind of CVT rebuild do I need?
  49. 2005 HCH Issue
  50. New 2003 HCH owner
  51. Can I take out my cats on my hybrid and it be okay?
  52. 2004 honda civic hybrid
  53. Hello
  54. Purge Valve Location
  55. Intermittent accessory problems
  56. Another P1600 post
  57. Drive without hybrid assist
  58. HCH-I DC-DC Converter Pinout
  59. 05 HCH will not shift to park
  60. 04 Civic Hybrid IMA Charging Problems
  61. looking to buy failed 03-05 hybrid civic
  62. CNG Civic GX???
  63. any hybrid owners on the site?
  64. Engine Noise/2006/2004 Civic Hybrid When Cold
  65. PC card for stereo
  66. New here....serious concern about the tires on my '06
  67. Should I, or Shouldn't I?
  68. if i got a hybrid
  69. Hypermileage
  70. Civic Hybrid switching/aftermarket parts
  71. Scratched CD/Radio display panel
  72. High RPMs at 60 MPH
  73. FE Test after Wheels, Spoilers, Added to HCH II: Pics & Techniques:
  74. Going Green
  75. civic/muscle hybrid... fuel economy what?
  76. check engine light keeps coming on
  77. Honda Announces Pricing of Natural Gas-Powered 2006 Civic GX
  78. Cheaper insurance for hybrid?
  79. Outpaced by Toyota?
  80. Post good Hybrid links for modding & dealers
  81. Real world gas milage
  82. top speed for a civic hybrid?
  83. Anyone here own a Hybrid? Review?
  84. Do they perform as well as regular ones?
  85. Honda Insight?
  86. How do you like your hybrid?...+
  87. Does having a hybrid really help?
  88. Cutting production?
  89. Better engine
  90. Cool look
  91. Gas savings calculators
  92. Short bit on how it works
  93. Poor ride?
  94. What is a hybrid vehicle?
  95. civic hybrid parts
  96. Do they lose Money on the Prius
  97. Reviews on Hybrids
  98. Putting a plug in gas use
  99. Hot hybrid
  100. What exactly is a Honda Civic Hybird
  101. Do Hybirds come with any options?
  102. 2006 Honda Civic Hybrid Wins 'World Car of the Year Award' for Greenest Car
  103. Battery pack replacement
  104. How does the Civic Hybrid compare to other Hybrids?
  105. Tire pressure
  106. Ethanol - can the Hybrids use it?
  107. Are Hybrids worth the money?
  108. Cheap hybrid on ebay
  109. Engineers modify hybrid cars to get up to 250 mpg
  110. Any modded hybrids?
  111. Why do you have a hybrid?
  112. Long-term prognosis on Hybrid
  113. Wrecked hybrid on ebay!
  114. Civic V Prius
  115. Honda dealer services
  116. Fuel Consumption
