Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Air Fuel Sensor for Honda Civic Hybrid
Old Jun 4, 2021
jubilation_l33's Avatar
jubilation_l33 is an unknown quantity at this point
Question Air Fuel Sensor for Honda Civic Hybrid
Hi ~ My manual Honda Civic Hybrid '05 was experiencing low gas mileage, the shop says it's cause I need a new "air fuel sensor".
I did some quick searches and I can't figure out whether it needs "36531-PZA-A01" or "36531-PZA-L01". What is the difference between the two? Is one upper and one lower, or something? What should I ask the shop to slyly get more info out of them so I can replace it on my own?
Any trusted sources of where I could buy one cheaper than Magestic Honda?
Thanks much to everyone for their help! xoxoxo
Old Jun 4, 2021
BrotatoChip's Avatar
Super Moderator
Re: Air Fuel Sensor for Honda Civic Hybrid
Is there a fault code? Ask them why they think it needs a new one.
36531-PZA-A01 is the one I'm seeing on HondaPartsNow.com. Not sure why there are two, maybe two different brands built them.
Old Jun 4, 2021
Yes so they said "found codes for air fuel sensor, repair quoted at $477"
I also asked them for the codes but they didn't want to give them to me? Said that air fuel sensor was all the info I needed. I did hear them say "upstream" and that it wasn't an oxygen sensor. I hope that info helps.
Old Jun 4, 2021
Super Moderator
Check engine light should be on then. Most parts stores will read codes for free. If the shop won't give you the code I wouldn't let them fix it.
Old Jun 4, 2021
Colin42's Avatar
Check densos website it will give you a part number
Old Jul 1, 2021
bobjen932's Avatar
bobjen932 is an unknown quantity at this point
36531-PZA-L01 is for California Emissions standards. 36531-PZA-A01 is the same part for the other 49 states.
viktor92
Feb 5, 2020 04:08 PM
jameyers77
Jan 13, 2014 07:21 PM
imported_Sam
18
Nov 23, 2006 01:04 PM
05blkrs
Jun 30, 2006 04:05 PM
TomH
May 11, 2006 12:08 AM
