Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Drive without hybrid assist
Old Sep 14, 2017
Nutcracker's Avatar
Nutcracker is an unknown quantity at this point
2003 Civic Hybrid. Check Engine light has been on since we bought it this year. (it's why we could afford the car...) The code says the battery temp is too hot. We confirmed that the cooling fan in the trunk is working, so no quick-fix available there. Then we disabled the IMA (switch "off" behind passenger seat, unplug the passenger-side wire cluster to the IMA, which is behind the "do not open" panel) closed it all up tight. And unplugged the cooling fan in trunk. 2 days later, "check engine" still on. Gotta get this light out to get inspected... any help out there? We can live without the hybrid part of this car, if we can only get inspected! Although, the plan is to get inspected, then restore the IMA with it's troubled "heat" code...we don't wish to replace the battery pack, just want to get inspected and get down the road!
Last edited by Nutcracker; Sep 14, 2017 at 06:16 PM. Reason: I think I need a better topic title
Old Sep 14, 2017
Re: Drive without hybrid assist
What fault codes do you get?
Old Sep 20, 2017
Nutcracker's Avatar
The code reads U0110, Lost communication with DMC module drive motor control module ... ,which I presume means The IMA since we unplugged it behind the backseat. So the only code we're getting is due to unplugging the IMA to the best of my knowledge. So I don't know how to work around this to get inspected
Old Sep 20, 2017
Seems the PCM knows it lost communication with that module and sets corresponding code for it.
There is no workaround IMO.
Fix what needs fixed the right way, or cut your losses and sell the car to someone else.
Old Sep 20, 2017
Nutcracker's Avatar
AND I forgot to mention, right after we posted that we restored the IMA/ hybrid system. (because of trouble keeping 12v battery charged up)
There's no "check engine" light yet, but when the hybrid batteries get warming up, we expect the original trouble code (sorry don't have that number) of the cooling fan for the battery, to trigger the check engine. We're trying to drive short trips and not heat up too much, and get inspected while the C E light is off...
Old Sep 20, 2017
Nutcracker's Avatar
Oh, just saw your answer. Thank you ezone!
Old Sep 20, 2017
Can you get the exact code numbers from 'battery temp is too hot'?
Old Sep 21, 2017
Nutcracker's Avatar
P1600, battery fan is what we were told
Old Sep 21, 2017
You were told incorrect information, by someone who has no idea how this works and/or is not trained and equipped to correctly deal with a Hybrid car.
Period.
P1600 is a "generic" code that exists only in the PCM (engine control unit), it's simply an indicator ......that is to tell the technician there are code(s) that must be retrieved from the IMA system. The code does NOT describe any condition other than there is a problem in the IMA system.
You need a much better scanner to read codes from the IMA systems.
You're going to chase your *** in circles and waste money without it.
You could spend a hundred bucks or so and take it to a Honda dealership and get correct answers quickly.
Old Sep 21, 2017
Nutcracker's Avatar
Ok I found a Honda dealer who will read the codes for 35 bucks, I will head over there tomorrow and hopefully pick their brain while I'm at it thank you again
Old Sep 21, 2017
$35 ???? Wow that's scary cheap!
I'm sure someone will want to know where this is?
Old Sep 22, 2017
Nutcracker's Avatar
Honda of Fort Worth, on west Loop 820. Orlando told me to come in and ask for him. This is a pretty rockin' dealership, with a great customer wait area and even kids play area. I'll have to post on YELP about it too!
Old Sep 22, 2017
Nutcracker's Avatar
P1449 is the code from the dealer battery module deterioration, battery cell overheating
Old Sep 22, 2017
It needs the IMA battery replaced. That's probably why the car was so cheap
Did the dealer shoot you a price for fixing it?
Old Sep 22, 2017
Nutcracker's Avatar
Yes! Around $3300 for the hybrid battery. Plus he said the 12v battery needs replacement, a strut is shot, a motor mount, a few more things. We are going to sell as is and get something else. Thank you for your assistance
