Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
2005 Civic Hybrid not starting
Old Nov 17, 2023
Timeout's Avatar
Timeout is an unknown quantity at this point
I have been gifted with a 2005 Honda Civic Hybrid. The starter wasn't engaging to start engine. Removed starter and tested. Seems to work fine on bench. Tried turning engine over with breaker bar and socket on crankshaft. Turns with much effort. Removed all the spark plugs. Didn't make much of a difference. It seems that the electrical end of the engine is binding up. This car had been sitting for about 6 months. I am pretty sure the 144 volt battery is done. The 12 volt battery is new. Any information on possible fix would be greatly appreciated
Old Nov 17, 2023
Colin42's Avatar
Re: 2005 Civic Hybrid not starting
Scrap it, take the money and run
Old Nov 20, 2023
BrotatoChip's Avatar
Super Moderator
Engine partially seized to the point where the starter cannot turn it. Engine will need replaced or fully rebuilt. If 144V battery is bad it also needs replaced. Definitely more cost than the car is worth.
daddydwriter
Oct 26, 2024 01:01 PM
DudeWithThe05
Sep 10, 2021 06:26 PM
gecad08
Electronics
Mar 20, 2020 04:33 PM
Dave88LX
Jan 7, 2016 11:03 PM
psuj22
Electrical
Jan 24, 2011 07:54 PM
