Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
2004 Honda Civic hybrid no crank no start
Old Aug 2, 2022
daddydwriter's Avatar
daddydwriter is an unknown quantity at this point
2004 Honda Civic hybrid.
New 12v battery, new starter, new relay fuse, car had originally died driving down the road. The hybrid battery doesn’t show any charge, it hasn’t been started since dec 2021. Doesn’t make any noises when I try to start it but all the electronics work…any ideas????
Old Aug 4, 2022
CivicGuy04's Avatar
CivicGuy04 is an unknown quantity at this point
Re: 2004 Honda Civic hybrid no crank no start
The radio should go off when you turn the key to the 'crank' position. If it doesn't, there is something wrong with your ignition switch.
Check the green 'key' light on the dashboard - the car won't crank if it doesn't detect the immobilizer chip key. Are you sure you have the right key, not one which is 'doors only, no starting', as sold by some third parties?
Normally, the radio will go off, there will be a brief delay, then the car will start using the hybrid assist motor. If the hybrid system has any faults (main battery below 11.5 volts or hybrid battery below 135 volts, too cold, too hot, or just in a bad mood), it will start with the regular starter motor.
If that doesn't happen:
Disable the IMA system. Remove the back seat, flip the big switch to 'off', remove the cover and unplug the data cables to the top left computer box in there. Keep your fingers clear of the high voltage stuff on the right! When reinstalling *put grease on the screw threads of the cover*.
Try starting it again. This time, it should directly use the starter motor. If that works, you have an issue with the IMA computer.
If that doesn't work, try bypassing the starter solenoid and see if it runs. If it does, the solenoid or wiring to the solenoid is broken. You could fix it... or let the car idle for 10 minutes to charge the big battery and then hope to never need the starter motor again because you'll always start with the hybrid system...
If it's a manual, try push-starting it too - it's a tiny engine so easy to do - just 5 mph is plenty.
Old Oct 17, 2024
civic_cuh's Avatar
Civic Cuh
civic_cuh is an unknown quantity at this point
have you found the issue or did you?
Old Oct 26, 2024
RFB's Avatar
RFB
RFB is an unknown quantity at this point
So I know this is a really old post, but it's the only thing I've found anywhere that is even close. So, I'm hoping you can expand on this a little. I also have a 2004 Civic Hybrid that decided to stop cranking. Mine does have about half capacity on the hybrid battery though. I have no idea why it won't crank. I tried following you advise by turning off the IMA big red switch and unplugging the data cables on the upper left computer. I was hoping this would force it to use the 12v battery and traditional starter, but that didn't happen. I have power in the car, everything seems to be working properly except the cranking of the hybrid system. I can hear something click from the hybrid system when I turn the key. It's a manual transmission, I was able to easily pop start it. So I'm fairly convinced this is isolated to the hybrid system somehow. The car isn't worth much, so I'm not sure if it's worth repairing, but I'd be perfectly happy if I could disable the hybrid and force it to use the traditional starter. I thought what you suggested above would do that, but since it didn't work I can only assume I didn't do it correctly. Any advice?
hemidenis
Jun 11, 2022 05:08 PM
hemidenis
Electrical
Oct 26, 2020 08:45 PM
trx680
General 10th Gen
Oct 20, 2018 05:52 PM
Stacy Price
Engine Swaps
Oct 20, 2016 09:38 PM
Gareee
Apr 2, 2012 07:56 PM
