07 Civic Hybrid -Starter battery replacement..need help!!
New to the form..
just wondering if I can replace the starter battery for a hybrid with a Walmart battery that is for an Lx/Ex.(not the hybrid battery in the trunk). Walmart doesent list a specific battery type for the Hybrid.. so i got the one that they recommended for the 1.8L, which is abourt 1.5" longer than the hybrid OEM one, but still may fit.
Does anyone know if this will cause any issues?
Re: 07 Civic Hybrid -Starter battery replacement..need help!!
i would use whatever you can fit that has a higher CCA (cold crack amp) rating than stock. the bigger the better but be sure battery has room. the "starter battery" is a regular lead acid nothing special.
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
dooner24
Apr 14, 2015 07:51 PM
