Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
R&R serpentine belt, '03 Hybrid?
Old Mar 25, 2021
CivicHybrid03's Avatar
CivicHybrid03 is an unknown quantity at this point
It is difficult to find much tech info on these cars.
Any help on replacing the belt - how the tensioner works, etc? Can't find video or much else.
Thanks.
Old Mar 25, 2021
Colin42's Avatar
Re: R&R serpentine belt, '03 Hybrid?
If it's an automatic tensioner then rotate the pulley away from the belt, should be straightforward from there. Take a picture of the belt routing if there isn't one on the car.
Manual tensioner loosen the bolts and rotate whatever component away from the belt
Old Mar 27, 2021
Thumbs up Re: R&R serpentine belt, '03 Hybrid?
Thanks. I'll check it out and snap some photos.
Old May 4, 2021
Photos, finally.
No belt routing label under the hood.
It's tight in there.
Are the circled bolts in the first photo the tensioner bolts?
Thanks!
Old May 4, 2021
Colin42's Avatar
That looks like an idler not a tensioner
Old May 4, 2021
never looked under the hood of a hybrid...
the bolt on the left is just holding the cover.
the one on the right, it have the slot. Maybe to actually remove the belt?
Old May 4, 2021
BrotatoChip's Avatar
Super Moderator
A quick Google search says the top is the tensioner but I don't know how it works. You'll have to dig into it to figure it out.
Old May 4, 2021
the right bolt is in a slot, so maybe it tilts the upper
dswall
Dec 27, 2014 08:28 AM
DBASRA99
May 27, 2014 07:58 PM
randomlyrob
Mar 19, 2013 11:30 AM
g_villa187
Mar 4, 2012 10:41 AM
jantipuna
Oct 6, 2011 05:18 PM
