Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Radiator cooling fans
Old Mar 25, 2021
curlywurly's Avatar
curlywurly is an unknown quantity at this point
I have a hybrid, but I would guess conceptually they are the same for cooling the radiator.
It has 2 cooling fans for the radiator, is it staged cooling process? First one fan comes on, then if needed, the other?
When I press the A/C max button only a
ingle fan comes on, I'm trying to ascertain if this normal, or 2 of the fans has failed.
Old Mar 26, 2021
BrotatoChip's Avatar
Super Moderator
Re: Radiator cooling fans
On the non-hybrid the two fans are tied together, you will never see one of without the other. My service manual doesn't cover hybrids though so I can't confirm.
Old Mar 26, 2021
curlywurly's Avatar
I would think, but don't know for sure, that the hybrid would be the same, it seems over-engineered to have a 2 stage fan process, but, as I'm discovering, the hybrid has many quirks!
Any hybrid owners - it would be appreciated if you could turn on the A/C to max a let me know if 1 or 2 fans turn on.
Thanks.
Hayden_Fourroux
May 16, 2020 03:35 PM
wsuguy28
Apr 30, 2009 03:14 PM
Baldie
May 10, 2007 08:57 PM
HondaLuver
Engine Swaps
Aug 3, 2005 11:40 PM
iamboo
Engine Swaps
Apr 30, 2004 06:05 PM
