Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
Purge Valve Location
Old Oct 20, 2018
Tabs0598's Avatar
Tabs0598 is an unknown quantity at this point
I have a 2005 Hch 1.3L and I have a P0497 code. Was told to replace the Purge Valve solenoid. I cannot find the location of this part anywhere and I’m fearing it may be tucked under the intake manifold. I can’t find what I’m looking for anywhere online, so any help will be greatly appreciated. Again, it’s the Purge Valve solenoid, not the Vent Valve.
Old Oct 25, 2018
mac25's Avatar
Dr Krieger of Modification
Re: Purge Valve Location
I'm not familiar with that engine but you should have a vacuum line going from the purge canister in the back of the vehicle, up into the solenoid and then into the intake manifold. So trace all of your vacuum lines and find the one that that heads down the firewall towards the back of the vehicle.
The valve should look like this...
Also you may want to check into testing it, if it works then try replacing the EVAP canister.
jdfrock2003
18
Nov 1, 2023 09:00 AM
Fox350
Nov 24, 2015 05:50 AM
Razgriz1500
Sep 15, 2012 11:29 PM
fernando97honda
Apr 2, 2011 10:49 PM
civichx81
Jun 27, 2002 04:39 PM
