- B20Z or B18A1
- 00' civic si coupe k24 swap
- I don't get swaps
- New member
- Need help finding information on B20 swap for '97 coupe.
- Swapping a D16Y7 from a 99 LX into a 97 EX that had a D16Y8
- What DOHC motor swap is the best for 2000 civic ex?
- D16B2 Swaps
- K swap
- Best ej engine swaps?
- Swap D To B
- Help please.... (Mini Me swap)
- D16y8 to B series engine swap
- Civic wiring help
- B18c swap on a 1996 civic dx hatchback
- J Swap 1996 EK Hatch AXLES
- Stock j32 Civic Idle Issue [solved]
- D16y8 Head to a d16y7 body [solved]
- 2000hx trying to put in a d15b
- k20/24 swap
- Is it possible to swap the drive train of a 2018+ accord 2.0t +10 SPD auto into a EK
- 1998 civic coupe k-swap
- D16Y8 swap into 95 ej....HELP
- My Honda cranks but No Start???
- K20A Swap
- Will the engine and tranny mounts line up?
- D16Y7 to a D16Y4
- K series swap better than a D series swap?
- b18b1 into a 97 ek hatch (MANUAL)
- Swaps for 00 Civic CX
- Swapping a D16Y7 for a D15B2
- CARB Legal Swap
- Best engine swap
- Ls vtec b20 blocks b16 head
- B20 swap 96 EK Hatchback (Automatic)
- Civic dx 1998 b series swap
- Weird vibration on h22a swapped civic
- Best/easiest b series swap-plug&play
- 1998 honda civic dx 1.4 engine swap
- 98 VTEC CIVIC swapping 99 vtec motor
- B16A2 Swap in 98 Civic HX Questions
- Can a 1.6 be swapped to a k22a4 in a 98 civic
- K Series Swap?
- Engine Swap Suggestions for EK
- engine swap
- Opinions on swap from D16Y7
- Hx to Ex
- LS4 Swap?
- Help regarding engine swap from a D14
- Motor swap putting a non Vtec into Vtec body
- EX to SI
- Project 96 Ex Ideas Please
- Not sure on the engine series. Clarification please
- Help K20 swap
- I want to engine swap my CivicDx 1999 coupe, what engines can fit in my car?
- Junkyard Swap help
- help on engine swap in chicago area
- D16Y7 to D16Z6 swap
- B16a ecu/wire harness
- the k-swap
- sedan swap
- b16a2 swap trans
- I am new and looking for help for my swap in my Civic DX
- 2000 Civic ex to B16B Swap
- 2000 civic ex d16y8 to b18c-s80 auto to standard,,
- Issues with d16y8 to d15b7 swap
- Engine swaps 101 for 6th gen and earlier models
- H-Series Engine Specifications, Swap Guides and Faq.
- D-Series Engine and Transmission Specifications..
- B-Series Engine and Transmission Specifications..
- sohc obd2a to sohc v-tech obd1
