Engine Swaps Post Questions about Engine Swaps here
Opinions on swap from D16Y7
Old May 13, 2020
Brice Cannon's Avatar
Brice Cannon is an unknown quantity at this point
I’m looking to boost my 98 5MT SiR HB and was thinking about a B16 swap from my current D16Y7 and thought I’d ask about other (possibly cheaper) swaps that would be close to the same?
Old May 13, 2020
FRSam's Avatar
Click Here
Re: Opinions on swap from D16Y7
Okay, a few things to discuss here.
It entirely depends on how much power you want to make. There are tons of threads on what the best B-series block is for boost (and 6th gen engine swaps), so do some reading on that. K is an option (though more expensive). Absolute cheapest engine swap (not being D-series) would be one of the LS engines. They're everywhere.
If it was me in your position, I'd buy a B18B block and save up for a proper LS/VTEC conversion before I boost.
Also: SiR's only came in a coupe for the 6th gen's (assuming you're in Canada) and they came with a B16A2 from factory. Sounds to me like you have a DX/CX.
Don't quote me on the SiR's coming only in coupes (though I'm 99% sure that's correct) but they definitely only came with a B16.
Old May 13, 2020
Okay, it says SiR on the dash(EJ6 HB) and the engine code was D167Y. As far as I know it’s bone stock, I am in Canada however so my SiR is the equivalent to the USA’s Si if that changes anything.
I’m not sure how to send pictures on here but I would be more then glad to provide a couple of I an figure out how.
Old May 13, 2020
FRSam's Avatar
Click Here
That dash has been swapped from a JDM model, I imagine. The only EJ6’s in Canada were the DX, CX, and maybe SE?
Old May 13, 2020
Oh okay how would I find out if it’s a DX or CX?
Old May 13, 2020
FRSam's Avatar
Click Here
Tilt-steering would be the biggest giveaway. CX’s didn’t have it until 2000, and DX’s always had it.
Old May 13, 2020
okay so it would be a DX thanks for your help and opinion on the swap also isn’t a B18B also good for low psi boost? I’m not looking to have absurd power(yet) I just want it to be faster and need a block that could handle a bit of boost reliability.
Old May 13, 2020
FRSam's Avatar
Click Here
B18B will handle 250hp with no issues. Boost entirely depends on the turbo you use. Low boost on a K03 is a lot different than low boost on a 6.7 Holset.
David Tugare
Engine Swaps
Apr 27, 2020 07:02 AM
TechniKalCancer
Mar 5, 2020 10:16 AM
Hayden_Fourroux
Nov 19, 2014 06:49 PM
Jimjimma6
Oct 23, 2014 08:03 PM
tb293009
Aug 12, 2013 08:40 AM
