Engine Swaps Post Questions about Engine Swaps here
engine swap
Old May 26, 2020
Jesse Smith's Avatar
Jesse Smith is an unknown quantity at this point
engine swap
I just bought a 2000 ex with a d16y7 engine thats blown and when I pulled the codes it says vtec system failure. I think someone put a non vtec motor in it and the computer is for a vtec, right? My question is what are my options for a new engine?
Old May 26, 2020
mac25's Avatar
Dr Krieger of Modification
Re: engine swap
Engine is blown (broken piston ring, broken rod, broken cylinder), or it just wont rev past 2800-3000? A vtec code will stop the vehicle from revving above a set point.
-non vtec engine needs a non vtec ecu and
-vtec engine needs vtec ecu
if you're not sure if your engine is vtec or not, check the block number and look for a vtec cylinder, since considering the age, you may have a mismatch in block and head, as well as ecu.
Old May 26, 2020
Re: engine swap
When I drove it it would bog down at around 3000 rpms
what do u mean vtec cylinder?
Old May 26, 2020
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: engine swap
The EX model comes with the D16Y8 VTEC engine, sounds like someone installed a non VTEC engine in that car. Or maybe someone just changed the block and used a VTEC head. Do you see a VTEC solenoid on the head? It is the small cylinder circled in red in this picture.
Old May 26, 2020
Re: engine swap
No there's no vtec solenoid but dude threw a vtec head in with the car bur i gonna switch gears with u guys I actually just bought a b18b1 block and transmission for it cuz I know they basically drop in. I'm experienced with working on all kinds of cars but I'm new to hondas and this will be my first engine swap. Have u guys ever done this swap? And what else do I need besides the engine and tyranny? I'll get a new non v tec computer I guess right?
Old May 27, 2020
BrotatoChip's Avatar
Super Moderator
Re: engine swap
Do a little research. Plenty of info here.
https://www.civicforums.com/forums/2...er-models.html
Old May 27, 2020
FRSam's Avatar
Click Here
Re: engine swap
Yeah, but cool people do LS/VTEC swaps.
I’m kidding haha, but I would recommend you read on it if it isn’t something you’ve heard of. It is actually pretty neat.
Old May 27, 2020
Re: engine swap
I'm trying to be cool but right now I'm only cool enough for a non vtec lol..
Old May 27, 2020
Re: engine swap
I'll check it out tho. I've ordered the b18b1 now I've gotta find the transmission. The thing I'm trying to figure out is what kind of ecu I need and if its compatible with the wiring harness I have now.
Old May 27, 2020
Re: engine swap
Hey it's still much better than the engine that's in it now. If you decide you want more power later you can always do a head swap.
Old May 27, 2020
Re: engine swap
Thats what I was thinking. I wanna have a good platform for the future, maybe even forced induction.. I know I'll need to lower my compression ratio but for now I'll focus on the task at hand
Old May 27, 2020
Re: engine swap
Whoever had this thing last mismatched everything, how do I find out if the ecu is obd2a or obd2b?
Old May 27, 2020
FRSam's Avatar
Click Here
Re: engine swap
Type in the code that’s on the ecu into something like eBay and it’ll give you the years that it applies to (it’ll either be 96-98 or 99-00).
OBD2A is 96-98 and OBD2B is 99-00.
Old May 27, 2020
Re: engine swap
Ok it looks like its an obd2a. Dang the kick panel just fell off when I touched it the ecu followed... it looks like this dude slapped this car together real quick to sell it
Old May 27, 2020
Re: engine swap
When I plugged in my scanner it said vtec system failure and there's no vtec head and when I drove it home it cut out at about 3000 rpms, does this mean the ecu is for a vtec? Which ecu do I need for my b18b1 Non vtec?
Old May 27, 2020
Re: engine swap
I eventually want forced induction can I convert to obd1 now?
Old May 27, 2020
Re: engine swap
If the ECU is setting a VTEC code then it's from a VTEC, a non VTEC ECU would have no way to know that VTEC even exists. It's setting that code because it is trying to activate VTEC and can't because your engine doesn't have it.
Old May 28, 2020
Re: engine swap
I'm looking at the p75-a04 ecu for my new b18b1 obd2a m/t. Do I have to reprogram it or how does that work? Thanks bros
Old May 28, 2020
Re: engine swap
Only if it has an immobilizer, if it doesn't then no programming is required. Looks like that ECU is from a 96-99 Integra. Only the 00 and 01 had an immobilizer, so you should be good. I just thought of something else too. Depending on what year that engine was made, it may not be legal to install into your car. Presuming you are in the US, federal law prohibits installing an engine that was built before the vehicle it is going into for emissions reasons, the engine must be the same year or newer. If you care you can look up what year car that engine is from by the VIN tag on the block.
Old May 28, 2020
Re: engine swap
Ok good. The b18b1 came out of an obd2a integra I talked to the guy thats sending it. My ex is an obd2a so I'm safe.
Old May 28, 2020
Re: engine swap
I was reading that u can't swap in an older obd version but u can of the same obd or newer. Dude on this thread sent me a link to an article on this site about ecu's, thats where I read about it.
Old May 28, 2020
Re: engine swap
Do I need the T bracket for the rear mount or not?!???
KINGTATE20
Dec 21, 2018 01:47 PM
crytikall
Jun 4, 2011 08:29 PM
chris0628
Jan 2, 2010 08:25 PM
msbastien
Oct 20, 2009 06:43 AM
supermex
South
Dec 31, 2002 07:49 AM
