Engine Swaps Post Questions about Engine Swaps here
Junkyard Swap help
Old Nov 8, 2019
Ajbutler's Avatar
Ajbutler is an unknown quantity at this point
Junkyard Swap help
I am currently on the lookout for a b20b from a CR-V to swap into my 2000 Honda Civic coupe. I am most likely going to be pulling it from a junkyard, what are some things I should do to freshen up the engine before I swap it into my car. New water pump, oil pump, etc..
If you have any other tips on swapping, I am open ears as this will be my first time swapping an engine. Thank you so much!
Old Nov 10, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Junkyard Swap help
Crv will be awd, won't it? May not work if you pull the rear driveshaft.
But rebuild wise
-valve seals
-camshaft seal
-valve cover seal
-main seals
-oil pan seal/liquid gasket
-new
Rings
Bearings (connecting rod/main)
Plugs
Probably other stuff I forgot, but rings and bearings are the main issues of high mileage engines.
Codel
Mar 12, 2019 12:22 PM
thedude7238
Aug 12, 2014 09:39 PM
owenkavanaugh
Engine Swaps
May 7, 2014 06:06 PM
dirtrick
Jan 2, 2014 08:34 AM
newsboy
Aug 3, 2012 08:59 AM
