Engine Swaps Post Questions about Engine Swaps here
2000hx trying to put in a d15b
Old Mar 15, 2022
martyc's Avatar
martyc is an unknown quantity at this point
Angry 2000hx trying to put in a d15b
ok i got a 2000 civic hx had a d16y5 i put in a d15b having issues with starting ...running rich white smoke smells like gas can anyone give me some info on what to do...chance ecu? or ? i put my intake on it anything else
Old Mar 16, 2022
FRSam's Avatar
Click Here
Re: 2000hx trying to put in a d15b
What exactly have you done? It can be an infinite amount of things.
Old Mar 16, 2022
Colin42's Avatar
What computer are you using?
checked timing?
Old Mar 27, 2022
martyc's Avatar
Sorry bout the late reply,ok what I've done so far....the stock or I should say, I haven't changed the ECU although I did bypass the knock sensor....I put my intake on the d15b,with the same engine harness.... basically the long block is all I put in my car hard to start if normal operating temp reached its even harder to start and running rich
Old Mar 27, 2022
FRSam's Avatar
Click Here
You need the accompanying engine harness and ECU. That’s probably why it’s not running great.
Old Mar 27, 2022
why did you put a D15B? it's for older cars than your 6th gen car...
is it just D15B or there are further codes? VTEC or not VTEC?
Boricuaboi
Electronics
Apr 7, 2019 02:28 PM
Forfast2
Oct 4, 2012 11:26 PM
bradsir
Oct 22, 2010 02:42 PM
kyle_l88
Apr 13, 2010 09:49 PM
awesomeaustin99
Apr 17, 2009 04:28 PM
