2000 civic sir swapped B16A help
Old Oct 18, 2010
bradsir's Avatar
bradsir is an unknown quantity at this point
i am haveing problems with the car and dont know where to start changed many parts, when idleing the rpms slightly fluctuate from around 1300 to 1700, it bogs down and will misfire in lower rpms as well. I have changed plugs, wires, distributor cap and rotor, alternator. what else should i try.?? i just bought this car a month ago drives great when after 2000 rpm and quick too. but please any info will help.
Old Oct 18, 2010
Mad Dog Tannen's Avatar
Re: 2000 civic sir swapped B16A help
If it is misfiring and the ECU is adding throttle or timing to compensate then you are probably throwing codes. Get your ECU read first, that should point you towards the problem.
Old Oct 18, 2010
bradsir's Avatar
theres one little problem with that the obdII connector is missing ive looked my self had three mechanics look for it im i ****ed without it ?
Old Oct 18, 2010
^ Kinda. Try to trace the wires from the ECU itself. It's gotta be there somewhere. Unless it was removed for some reason. When it got swapped it someone could have just been too lazy to run the wires to under the dash. I guess they could be missing completely but you would be able to tell by looking at the ECU.
Old Oct 22, 2010
bradsir's Avatar
how can i tell by looking at the ecu because i look and couldn't find much lol
Old Oct 22, 2010
They would be the wires that lead to no where or to the plug for the reader.
Old Oct 22, 2010
02civicsi02's Avatar
Low and slow!
First off why did you swap out the b16a2 for the b16a. That is really not that much off a upgrade. Should of at least went with a b18 or k20.
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
