- In Park, after applying the brake, the car still rocks backwards when you park
- Wondering--maybe lazy because of extreme heat here in Maryland
- Driver side cv axle splines
- Filling Transmission Thru Check Bolt
- 2019 Civic LX will not move into Drive
- CVT problem
- 2018 Civic Clutch STILL smells after replacement
- Shifter has resistance moving side to side only and struggles to return from reverse.
- Honda Touring 2020 has burned out clutch after only 17000 around town driving[solved]
- 4.8L came out of the CVT drain plug, what next?4.8L came out of the CVT drain plug, w
- Transmission service? [solved]
- Replace CVT?
- Manual transmission noise at take off
- 2017 Honda Civic EX-T w/ CVT - Clunking = Transmission Failure?
- Hard jerking after using sports mode.
- Metal on trans drain plug
- Random engine revving on the highway at 70mph Anybody?
- Strange Knocking noise on 2018 Civic Sport Hatch
- Civic 2018 CVT transmission oil
- 2018 civic LX - Manual trans
- 2016 Automatic Startup Drive Shifting
- 2nd gear grind
- CVT 2018 LX filter
- Clutch pedal vibration/feedback all gears at around 4K [solved]
- 2014 Civic transmission failure
- Leak from CV boot area above oil drain pan
- CVT engage “tug” do you feel it.
- 2020 civic si buzzing noise at 3k rpm that comes and goes!
- Honda doesn't provide remanufactured CVTs?
- RPM surge when shifting gears
- CVT Trouble
- 2020 Civic Auto shift lever clicking sound
- Half Shaft Bearing
- Sputtering When Pressing Clutch In 1st Gear
- 2017 civic transmission oil change question
- 2020 Civic SI Clutch Component Failure [Honda noow taking warranty]
- Transmission noise
- Sudden Gear Lockout
- Transmission Leak 2016 Honda Civic Touring
- 2018 clunky
- Cvt fill plug [solved]
- 2017 CVT and Radiator
- 2017 rolls back when in gear
- 2017 hatchback When I change to reverse, It take 2-3 sec to change
