Filling Transmission Thru Check Bolt
Old May 3, 2025
Saratoga's Avatar
Saratoga is an unknown quantity at this point
My 2020 Civic LX is due to have its transmission fluid changed. You Tube videos I watched shows that it is necessary to remove the cover at the front of the engine compartment and the air cleaner housing to get to the fill plug. Since the the check bolt needs to be removed to ensure the proper level of the transmission fluid would it be advisable, with a funnel that has a 90 degree bend, to fill the transmission thru the check bolt hole?
Old May 4, 2025
Colin42's Avatar
Re: Filling Transmission Thru Check Bolt
Do it through the fill plug
Old Oct 26, 2025
widude's Avatar
widude is an unknown quantity at this point
I don’t see any reason why not, through the check bolt. You end up at the same level.
I considered it, but it wasn’t hard to remove the air box. I also shifted into low gear to get the linkage away from the fill hole, engine off of course.
Millsy088
General
Jan 1, 2022 07:43 PM
onlycodered
May 25, 2010 05:56 PM
hunch1784
Jan 1, 2010 07:43 PM
starfox
Oct 21, 2008 08:52 PM
AnotherDopeStyle
Sep 13, 2002 02:06 PM
