2017 Honda Civic EX-T w/ CVT - Clunking = Transmission Failure?
Old Oct 20, 2023
osmg's Avatar
osmg is an unknown quantity at this point
My wife's 2017 Honda Civic EX-T w/ CVT (~125k miles) began making a loud clunking sound between approx. 5-25 mph. I lifted each side of the vehicle, rotated the wheel by hand, and was able to reproduce the sound. Here's a clip:
It's hard to see in the video, but the inner CV spline which goes into the transaxle is loose, and moves side-to-side about 2-3mm while turning. The CV joint itself is tight - the movement is where the spline enters the transaxle housing...
Besides the movement, you can hear the clunk in the video. Also, I lift each side of the vehicle, and each side is exactly the same, so I'm sure it's not the CV joints.
I found an entire differential assembly for only ~$300 but I'm not sure if there might be something else going on.
https://www.hondapartsnow.com/genuin...0-5lj-003.html
Does anyone have experience with this? Any insight would be much appreciated!
tomas6791
Nov 15, 2016 07:10 AM
sk9000
Feb 11, 2016 04:11 PM
bashea
Sep 15, 2015 04:59 AM
jmtikhonoff
Jan 19, 2013 10:07 PM
tastyratz
Apr 10, 2006 08:10 AM
