CVT Trouble
Old Nov 22, 2020
zkayani's Avatar
zkayani should not be trustedzkayani should not be trusted
CVT Trouble
Hello everyone, I made a big mistake with my 2016 Civic Touring. I was attempting to replace the engine oil but I mistakenly drained all of the transmission fluid and refilled my engine with 4 extra quarts of oil. I drove the car for about 20 seconds before it completely stopped. I corrected my mistake and the CVT seems to have a delay whenever shifting from park to reverse or drive. Have I completely messed up the transmission from 20 seconds of driving? And is that enough time to mess up the engine while it has too much fluid?
Old Nov 22, 2020
FRSam's Avatar
Click Here
Re: CVT Trouble
Just to clarify, you drove 20 seconds with no trans fluid at all?
Old Nov 22, 2020
Re: CVT Trouble
Are you sure it hasn't been this way since it was brand new?
They DO delay engagement, sometimes it feels like several seconds of delay, under some conditions as a self protection measure.
Better compare to an identical car before you decide yours has a problem.
Old Nov 22, 2020
zkayani's Avatar
Re: CVT Trouble
It used to have a delay of about 5 seconds, now it has decreased to a less noticeable number but you can definitely tell there is a delay. We bought the car about 2 weeks ago with 50k miles and it was beautiful before I messed it up. I actually have owned a few of these civics in a lower trim as projects and even those shifted immediately
Old Nov 22, 2020
zkayani's Avatar
Re: CVT Trouble
Yeah
Old Nov 22, 2020
Re: CVT Trouble
Re-read.
So the delay is actually less than before?
But your issue is the delay?
Old Nov 22, 2020
zkayani's Avatar
Re: CVT Trouble
Originally Posted by sdaidoji
Re-read.
Yes, although the delay is not as much as it was when I first drove the car after my accident, there is still a slight delay. I want to know if this is really something to be concerned about and if there is a way to improve the delay
Old Nov 23, 2020
Re: CVT Trouble
ah, sorry, i thought you were actually answering the question about before and after.
Your response was not a reply, but comparing right after the issue and now.
Old Nov 23, 2020
zkayani's Avatar
Re: CVT Trouble
I believe it should be implied from reading the original post that there is a larger delay from when the car was purchased to after a few days of fixing my error.
Old Nov 23, 2020
Re: CVT Trouble
Really? Each and every one of those project cars was equipped with Hondas 1.5 turbo engine and next gen CVT transmission?
I'm sorry, I did not realize "identical" would be such a difficult concept.
What kind of fluid did you put in the transmission?
Old Nov 23, 2020
zkayani's Avatar
Re: CVT Trouble
I have owned the 2016 EX-T, and the 2017 EX-L before this one, both of which are the exact same as the touring mechanically. The transmission fluid used was HCF-2. But it's fine I just replaced the CVT yesterday and now it shifting in less than half a second compared to 2 seconds. Also if someone needs genuine help with something regarding their car, you probably should stay far away from giving them advice.
Old Nov 23, 2020
FRSam's Avatar
Click Here
Re: CVT Trouble
Old Nov 24, 2020
Re: CVT Trouble
So, you posted yesterday about the issue, but had already replaced the transmission?!?
That begs the question: Why did you post about it anyway?
Since you are a newbie here, let's just lecture you about one thing:
He solved some almost impossible issues in here, from an internet distance.
He works on cars all day everyday. He just don't have patience with people that already had replaced the part but still posts questioning about it....
I believe it should be implied from looking at his "Rep Power", legitimately received in this forum that few people actually gives rep points when they have their issues solved by a member.
Old Nov 24, 2020
Re: CVT Trouble
Also, curious about this, why are you on the third civic at the age of 20?
bmarcinczyk14
Oct 22, 2013 12:26 PM
WaryDriver
Dec 30, 2011 11:44 PM
IrockCivics
Jan 22, 2006 08:00 PM
btwracing
Apr 25, 2004 03:43 PM
iamboo
Apr 30, 2002 08:02 PM
