Replace CVT?
Old Jan 7, 2024
jkwraase's Avatar
jkwraase is an unknown quantity at this point
Question Replace CVT?
I have a 2014 Civic with only 27,000 miles, I noticed a chattering sound that occurs at any speed, but goes away if you slip it into neutral.
The dealer asked if they could change the transmission fluid to check for metal shavings. They reported that the existing fluid was "burned" and probably damaged the transmission.
They can't tell me what exactly is broken, they are only recommending a transmission replacement for $7000. Also the sound became louder after they changed the transmission.
How can i find out what is really wrong with the transmission and if it can be repaired?
Thanks!!!
Old Jan 7, 2024
Colin42's Avatar
Re: Replace CVT?
Generally they aren't repaired, just replaced
Old Jan 7, 2024
jkwraase's Avatar
Re: Replace CVT?
Thanks, interesting. Is there a known issue with these transmissions?
I have owned 5 Hondas over the last 40 years prior to this one and always found them the most reliable cars.
Also the dealer mechanic said that I could ignore the noise and skip replacing the transmission, since it wasn't going to leave me stranded.
Not sure how he could say that if he did not know exactly was was wrong with the transmission.
Has anyone just let these transmissions keep going once they start making noise?
Thanks!
Old Jan 7, 2024
Colin42's Avatar
Re: Replace CVT?
The early cvts were problematic. Never owned one and i dont plan on owning one
Old Jan 7, 2024
FRSam's Avatar
Click Here
Re: Replace CVT?
27,000 miles is definitely premature even for these transmissions. They were never the smoothest but it shouldn't be damaged yet.
I'd let it go until failure and then reevaluate.
Old Jan 8, 2024
jkwraase's Avatar
Re: Replace CVT?
Thank you.
mutineer
Transmission
Apr 16, 2025 06:12 PM
noodles
Regular Maintenance
Jul 7, 2021 02:40 PM
DeuilEtoiles
Transmission
Nov 28, 2019 01:24 PM
neillany
Feb 13, 2010 10:02 PM
es2k2
Chicago
Apr 25, 2005 09:45 AM
