2nd gear grind
Old Mar 16, 2022
Maddoxmalan123's Avatar
Maddoxmalan123 is an unknown quantity at this point
2nd gear grind
I have a 2018 Honda Civic si it only has 40k miles but 2nd gear grinds. You can put it in to 2nd but you have to put it in slowly. Even then it will still sometimes grind then pop out. What could be causing this?
Old Mar 17, 2022
FRSam's Avatar
Click Here
Re: 2nd gear grind
Sounds like the synchros are failing. Looks like whoever was first driving it was new to driving manual.
Old Mar 17, 2022
Re: 2nd gear grind
i was told it would be the teeth to the second gear would this be true?
Old Mar 17, 2022
FRSam's Avatar
Click Here
Re: 2nd gear grind
It could be. I hope for your sake it isn't, though. That means a crapload of clutchless shifting by someone who has no idea what they're doing.
Old Mar 17, 2022
Re: 2nd gear grind
i heard it was common in the si I really hope someone who drive manual like that gets their manual driving rights taken away
Old Mar 17, 2022
FRSam's Avatar
Click Here
Re: 2nd gear grind
Yeah, I'll admit I'm not super familiar with the 10th gen. Could be a relatively simple fix but it sounds like it's beyond that now.
Old Mar 17, 2022
Re: 2nd gear grind
crap one last question how much do ya think the cost to fix would be by dealership
Old Mar 17, 2022
FRSam's Avatar
Click Here
Re: 2nd gear grind
I have no idea. It depends on whether it's a synchro or the actual gear. If it's the synchro, cheap enough (probably in the $500-$1000 range based on labour). If the gear needs to be replaced (not sure if that requires a full trans replacement or if you can just change the gear), but you're easily looking at a few grand there.
I'd have a shop look at it to confirm.
Old Mar 17, 2022
Colin42's Avatar
Re: 2nd gear grind
If you're confident, you could get a used trans and swap it yourself, cheaper than paying someone to change a gear/synchro
Old Mar 17, 2022
Re: 2nd gear grind
I can’t I wish I could. How much is it going to cost roughly?
Old Mar 17, 2022
Colin42's Avatar
Re: 2nd gear grind
Call a shop, probably around $2k
trev0006
Aug 28, 2006 03:54 AM
pbfoot
Aug 3, 2004 02:22 PM
iluvbritney
Jan 2, 2004 01:19 AM
