Cvt fill plug [solved]
Old Mar 15, 2018
Steve Bachman's Avatar
Steve Bachman is an unknown quantity at this point
3 or 4 times in the last 20k miles or so, my cvt fill plug has popped out and was laying on top of transmission. Im assuming it building up pressure but not sure if there is a vent that may be clogged? What would cause it to pop out? I do the drain and refill service every 30k
Old Mar 15, 2018
re: Cvt fill plug [solved]
I've heard they do it.
I haven't heard of a real fix yet.
Check if the trans vent tube cap has become plugged?
Old Mar 15, 2018
CraigW's Avatar
On my 05 the AT dipstick fit very loosely in place....then, member gearbox posted about a new design & part # for the dipstick. Fit much better.
Check Honda parts sites and look for part # changes to see if improvements have been made.
Old Mar 31, 2019
Jimbo64's Avatar
Jimbo64 is an unknown quantity at this point
I’m having the same problem with my fill plug popping out. Does anyone know if this plug is supposed to have O rings to keep it snug ? I had a drain and fill when I found it sitting near the battery because there’s no way of checking the level . The mechanic said the plug looked fine, however it popped out again.
Old Mar 31, 2019
Colin42's Avatar
The vent may be clogged and pressure is building up and then popping the plug
Old Apr 1, 2019
Jimbo64's Avatar
Thanks, would you be able to tell me where the vent is located? Is it accessible through the engine conpartment ?
Old Apr 1, 2019
Colin42's Avatar
look for a black plastic cap somewhere on top of the trans
Old Apr 1, 2019
Jimbo64's Avatar
Thanks for your help . 🙂
Old Apr 1, 2019
Would be helpful if we knew specifics about your particular car
Old Apr 1, 2019
Rastan13's Avatar
Rastan13 is an unknown quantity at this point
The fill plug came off twice by itself. The last time was after merging into traffic with fast acceleration.
The vent plug after removing it. Cleaned it next.
The vent tube
The same thing happened to my 2015 Civic EX-L. I found the vent cap completely clogged. I cleaned it out and hopefully this resolves the problem.
Old Apr 1, 2019
Jimbo64's Avatar
Thank you very much. I will let you know how I do .
Old Apr 7, 2019
Jimbo64's Avatar
I went about a week. Five hundred mikes and the plug stayed in . Last night it popped again so I found the plug and ran a small ty rap through the plug and the vent cap to clear any clogs. I’m going to see what happens . Thanks again .
Old Dec 11, 2019
rayscdn's Avatar
rayscdn is an unknown quantity at this point
can you point me out where is the breather is located?
Old Dec 11, 2019
Colin42's Avatar
There's a picture like 5 posts up...
Old Mar 9, 2020
Brian Hofstra's Avatar
Brian Hofstra is an unknown quantity at this point
I have a 120000 miles on my civic LX. Have had it serviced at the Honda dealer for every oil change. Never did the transmission service. A month ago my son was driving it and called and said it wouldn't move... Opened up in hood and found the transmission plug had popped out and oil everywhere. Now the transmission is ruined and the dealer and Honda customer service won't do a thing. I'm beyond frustrated
Old Mar 9, 2020
Rastan13's Avatar
Angry re: Cvt fill plug [solved]
Seems like the 2013 - 2015 models have this problem. I used a tie wrap to keep mine from jumping out and I keep the breather cap clean.
Old Oct 9, 2020
Nikki Harmon's Avatar
Nikki Harmon is an unknown quantity at this point
i zip tied mine down and it blow transmission fluid out underneath it
Old Nov 9, 2020
Fawalley's Avatar
Fawalley is an unknown quantity at this point
Hi All. Just where exactly if you're standing at the front of the car looking down at the fill plug is the vent plug? Thinking of doing a fluid and filter change in a day or two and want to clean it out but I can't see it. Thanks all.
Old Nov 9, 2020
look below the radiator hose fitting
Old Nov 10, 2020
Fawalley's Avatar
Thank You. There were so many places it could have been. Yes, it was plugged. I cleaned it out and turned it to face at a 2 o'clock position rather than the 6 or facing the radiator which it was. Did a small video which I'll post later.
Thanks again.
Old Dec 27, 2021
SFTom1251's Avatar
SFTom1251 is an unknown quantity at this point
My transmisdion Fill plug Popped out without it being touched by anyone. Had car towed 57 miles home and then to 3 different shops. Extended warranty folks are balking by saying I drove it without tranny fluid (IDIDN’T—I stopped car at first sign of trouble and had it towed home), or that shop looking at the first time put the wrong fluid in it (THEY DIDN’T), and that a rock i hit on the highway created a hole in tranny pan( IT DIDN’T—thought this might be correct but inspection revealed no hole on far passenger side. All the fluid showing was from drivers side from around fill hole where plug was dislodged).
Honda says I need new tranny at $8500. Extended warranty people have a listed of excuses—all wrong thus far.
This is a base model 2016 Civic with 130K. Any suggestions on how to proceed with Honda and the extended warranty bandits? I’m gonna try a few more reasonable responses before I go to Court (where I’ll likely prevail I’m plaintiff-friendly Northern California) but want to avoid that for many reasons.
Old Feb 17, 2022
Cesare's Avatar
Cesare is an unknown quantity at this point
Re: Cvt fill plug [solved]
I have more than one radiator hose. I've looked sal over and can't find the vent screen. Could you be as specific as possible, please?
Mine is a 2015 Honda Civic
Old Feb 17, 2022
Colin42's Avatar
Post 10 has photos
Old Feb 17, 2022
this thread is for 10th generation cars.
2015 is a 9th gen car.
not sure if they changed designs or not
Old Nov 15, 2024
cpardoe's Avatar
cpardoe is an unknown quantity at this point
Hi, What did you end up doing? I’m having the same exact problem with my 2014 civic lx and I’m at a loss of what to do
Old Nov 16, 2024
Colin42's Avatar
Did you even read the thread?
cherbear13
Transmission
Oct 9, 2020 01:37 PM
msidd
Mar 14, 2018 10:45 AM
Shad Welch
Transmission
Feb 13, 2018 07:19 PM
2008CivicHybrid
Transmission DIY
Jul 22, 2017 10:01 AM
ridethelighting
Nov 10, 2011 12:09 PM
