- DIY Tune Up ?
- Possible fuel filter?
- Synthetic oil or Conventional???
- 02 Civic fuel injector cleaning port
- General questions about my new Honda Civic
- How many quartz to change MTF Manual Transmission Fluid for 01 Civic
- Transmission fluid
- 2001 Honda Civic EX - 132,000 miles (need more)
- Deciding how far to go on maintenance
- Oil change interval?
- Maintenance
- 2004 Civic - changing the fuel filter
- Got a 03 civic ex with maintience required light
- What's the most painful regular maintenance items for you on 7th gen?
- Engine air filter cover bolts corroded and won't come off
- Timing Belt Question
- Oil filter question
- Power steering fluid other than honda brand
- New 04 Civic Owner.
- 2004 civic transmission fluid change
- Honda Civic EX Special Coupe exhaust and maintence
- oil change intervals
- timing belt
- Iridium or platinum plugs?
- 2004 timing belt duration
- Conventional oil or Synthetic oil to top off civic 2002?
- Is Wrong Oil Bad For Older Civics??
- Replacing nuts and bolts
- Timing belt & water pump on a timeline or just mileage based?
- What oil should I use in a northern climate?
- Bought an 04 coupe, suspension maintenance?
- Cvt or ATF fluid
- Blinking "Maintenance Required" light
- Manual Trans?
- after how many YEARS should the timing belt be changed?
- Advice on what tools to buy for basic maintenance?
- need help with catalyic convertor selection
- Changing oil on '04 EX
- When not to change ATF Trans Fluid?
- Gonna do a tune up. Am I missing anything?
- Best Oil to use
- Maintenance required light
- What is the recommended mileage to change fuel filter?
- MAINT. REQ'D light WON'T turn off!
- Maint Req. Light
