Engine air filter cover bolts corroded and won't come off
Wondering if any of you experienced DIY Civic owners have run into this problem of some of the 7 screws that hold the engine filter cover secure have corroded so much that they will not come off?
They are 8 mm but my 8 mm socket just won't grip these two screws closest to the center of the engine and these two are obviously rusted. the other 5 removed easily.
I am trying some things I found on this website but without movement of the screws yet. https://www.bobvila.com/articles/how...rusted-screws/
Of course I can take it into a repair shop but I've gone this far and have the new filter and would just like to get this done!
Also, am I able to purchase replacement screws from Honda once I get these two loosened? All experience appreciated!
Re: Engine air filter cover bolts corroded and won't come off
Hammer a slightly smaller socket on? Try an imperial size. The screws are captured in the lid, you could try the junkyard and see if there's a lid with good screws. Or put on one of those shiny chrome intake tubes all the cool kids use.
Get a set of bolt extractors if the smaller socket method doesn’t work.
IRWIN Bolt Extractor Set, 5-Piece (394002)
IRWIN Bolt Extractor Set, 5-Piece (394002) https://www.amazon.com/dp/B000QW6K8I..._lGghFb3GZEZDS
Don't bother contacting a dealer, screws by those dimensions from a hardware store will work just fine.
The stock screws don't have threads all the way along the shaft, but normal screws, that do, will be okay.
JRunyon21
Oct 5, 2012 08:34 PM
2005h4
Sep 6, 2005 02:51 PM
