Help changing air filter
Old May 7, 2010
JRunyon21's Avatar
JRunyon21 is an unknown quantity at this point
I will be changing out a few things this weekend and one of them is going to be my air filter. It hasn't been changed since I got the car(60000k ago) and probably wasn't changed before that(Ouch!). So it deff needs done.
I am very new to car maintenance but I am tryin to learn as quickly as possible. Is there a DIY on this website for the air filter? I found one for a cabin air filter but not one for the engine air filter. I heard it is one of the easist things to replace. Any help is greatly appreciated.
2004 Civic VP
-Jason
Old May 7, 2010
Re: Help changing air filter
just undo all the screw/bolts on the top air cleaner housing halfway and pull the top half off. the screws only need to be removed til they are loose, its easier if they stay threaded in the top housing but its possible to completely remove em if wanted. the worst thing that happens is the screws are too tight and it cracks the housing due to someone making them too tight from last time. so you may plan on needing a new air filter housing if yours breaks. otherwise once the top is off, pull out the filter and install the new one in the same way so it lines up and seals properly. carefully put the top back in and make sure it is seated properly, then tighten the screws hand tight with a screwdriver (not a socket wrench).
Old May 7, 2010
seoul4korea's Avatar
seoul4korea can only hope to improve
its super easy...
Old May 20, 2010
chill_05ex's Avatar
chill_05ex is an unknown quantity at this point
The screws will accept a phillip's head screwdriver, but a 10mm socket will give you better grip on the screw head.
Old May 20, 2010
BlueEM2's Avatar
Whachya lookin at?
Use the socket, because after you use the Philips a few time they get so stripped you have to use the socket anyway.
Old May 21, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
As was mentioned, just make sure you don't overtighten when putting it back together. It should be firmly tightened, but you shouldn't be straining once the bolt starts resisting more than a bit.
Old Jun 16, 2011
yhamskie's Avatar
yhamskie is an unknown quantity at this point
sorry for reviving this forum, i bought a second hand toyota corolla last year, and I want to replace my air filter,unfortunately most of the screws lost its thread so I can't remove the air cleaner housing, can anyone help me to remove those screws without damaging the air cleaner housing. Thanks
Old Oct 5, 2012
FreeCarSupport's Avatar
FreeCarSupport is an unknown quantity at this point
Here is a great write up on how to do it including pictures and everything!
http://freecarsupport.com/diy-write-...s#.UG-HIKRYt7Q
vtecbrah
May 31, 2015 01:24 PM
vtecbrah
May 12, 2015 01:30 PM
carid
Apr 30, 2015 07:00 AM
