What is the recommended mileage to change fuel filter?
Hey guys,
I'm wondering how many miles should our cars have until we should change our fuel filters? Just a maintence issue. Thanks.
There is no set mileage of fuel filter change. If you feel your car is not reacting even when you cleaned your fuel injectors, oil changed, spark plugs changed, trainsmission fluid changed then you have narrowed down to fuel filter problem. Fuel filter is not part of your common maintenance list. You should check this during your next major tune up.
Originally posted by civic01vtec
i change mine every 10K
End Bringer
most of the time, changing the fuel filter is a "feel good" maintance, it's pretty much whenever you want to do, that will make you feel good
fuel filters can last quite a while, but under heavy load and tempature conditions, it's recommened to change once per 1-2 years
the fuel filter is near the gas tank
Originally posted by Da1lyDr1ver
isnt there a fuel filter under the hood? or is it really under the rear seats by the gas tank?
does anyone have a DIY on this, i'd like to do mine too!
A descendant of 2k1civic.com
Well I assume I'll be a pioneer and make the DIY when I do it.
Here is something interesting. The guy at the dealership said the filter is a lifetime part and that I didn't need to change it, ever.
That doesn't seem right, does it? Gas is some unfiltered, unpure crap and that filter has to get bad sometime. right? Anyways. I know that going too long before changing the filiter puts some unnecessary strain the fuel pump, because it has to work harder to get the fuel through the filter when too much crap is built up in there. So . .I didn't buy one when I was at the dealer, but I think I'm going to get one anyways. Does anyone know a place to pick one up? Thanks again..
End Bringer
you don't have to go to honda to pick one up, your local pep boys, autozone and advance discount should have it
the only time i saw a dead fuel filter, was from a 1985 buick somerset, that thing was a pos with rusted exhaust and the whole 9 yards, we ran a solution through it one end, and nothing came out from the other. remind you this solution is for cleaning out the gunk and muck in engines
when you install the fuel filter, makesure you have the direction right, must go on the way it suppose to
Re: What is the recommended mileage to change fuel filter?
Fuel filter in my 93 hatch
chaoticmav
Feb 24, 2006 02:40 PM
Bires
Mar 18, 2005 12:10 PM
civic02ex
Jul 12, 2003 10:52 PM
