Regular Maintenance Post Questions/Information about Regular Maintenance here
2004 civic transmission fluid change
Old Apr 19, 2020
Lennon Fay's Avatar
Lennon Fay is an unknown quantity at this point
I have a 2004 civic lx and it has about 144k miles on it and from the service records i can see it last had a transmission fluid change at 27k miles back in 2010
I read that in older automatic transmissions you shouldn't change the fluid at this point
Do you guys think it's too late for me to change the fluid? It isn't a super dark black color it's a light reddish brown I think
Old Apr 19, 2020
FRSam's Avatar
Click Here
Re: 2004 civic transmission fluid change
Not sure why it would be too late to change it. Maybe too late to flush? I don't see any issues with draining and refilling.
Old Apr 19, 2020
Slumpertcivic's Avatar
Drain it, refill with Honda.
Drive fast enough for the car to shift into 4th, run in reverse for a few feet.
Wait for car to cool down some.
Repeat at least one more time, preferably 2 more times.
Consider doing same for coolant system, except I like to drain, refill with distilled water only, drive for a bit drain, refill with distilled water again, drive and drain then refill with 3 quarts of concentrated anti freeze and top off with more distilled water.
Old Apr 19, 2020
There are thoughts that the “old contaminated” fluid can help failed clutches get a slight bit better grip. Certainly proof that “flush” machines can clog up stuff and “kill” the transmission
But it’s more likely the old fluid is causing excessive wear by limiting pressure the pump can exert on the clutch discs allowing them to slip and wear down faster resulting in dirtier fluid and further wear..
Old Apr 19, 2020
Simple drain and fill using the correct fluid is always safe and is the procedure in theiir service information
Honda doesn't approve using extra chemicals or a flush machines.
Old Apr 21, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
The new Honda DW-1 ATF is synthetic and should perform better than the old Z-1 that was probably used in 2010. Drain and fills only. Never flush.
Old Apr 22, 2020
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I agree. I believe most of the stories about failures after changing the fluid are because people wait to change the fluid until they are having problems and then when the transmission fails they associate it with changing the fluid.
Boomer242
Transmission
Dec 26, 2019 08:24 PM
AP4114
22
May 1, 2016 09:43 PM
hurtingbad
27
Sep 26, 2013 02:20 PM
Digipixel
16
Jun 12, 2012 12:30 PM
green01civic
Nov 11, 2010 10:09 PM
