Regular Maintenance Post Questions/Information about Regular Maintenance here
Changing oil on '04 EX
Old Oct 26, 2013
G_ROBB89's Avatar
G_ROBB89 is an unknown quantity at this point
Hey Everybody,
The manual says I need a special wrench to remove the oil filter (that I can buy at a dealership). Do I need a this "special" wrench or is Honda just trying to get more money out of me?
Thanks.
Old Oct 26, 2013
Tragedy's Avatar
skate or die
Re: Changing oil on '04 EX
Use a oil filter wrench. Many varieties.
Old Oct 26, 2013
I use one like this the most, removal only.
There are plenty of other styles too, google it
If you can't get the filter off with your hands, you will need a tool of some sort.
You can use darn near anything to remove it, no concern with damage.
I install the filter by hand.
Old Oct 26, 2013
You know that's misspelled, right?
Old Jan 3, 2014
Dustyrandall's Avatar
Dustyrandall is an unknown quantity at this point
You can get the tool at a store for a couple bucks. Or jam screw driver through the filter to assist your hand turn.
Old Feb 19, 2019
7thgen2004's Avatar
7thgen2004 is an unknown quantity at this point
I own similar model,used to change the filter 4-5 times per year,and I never needed wrench not even sigle time.all hand tightening &loosen
Old Feb 19, 2019
Colin42's Avatar
Well as long as the filter is installed properly with a lubricated gasket and the oil change is not severely overdue, 95% of the time it will come off by hand. Unless it's a Toyota, those damn things seem to glue themselves on
Old Feb 20, 2019
Slumpertcivic's Avatar
Reminds me, maybe I should punch a hole in the filter before removing.. drain it out before it all dumps out.
MarkieMark
May 2, 2021 02:36 PM
EVO LOL
Mar 16, 2009 10:52 AM
Boggie1688
Jun 23, 2005 11:35 AM
jameStype
Apr 18, 2005 10:29 AM
redvtec04
Mar 31, 2004 10:13 AM
