Oil change interval?
Hello,
I own my 3rd ever 7th gen civic. 2004 lx 4 door. I owned it since 140k miles, it now has 213,900 miles. Just got a new timing belt, water pump, tensioner, plugs, crank and cam seal. Everything looks like normal wear. Anyways, I've been religiously changing the oil every 5,000 miles or 6 months, whichever first since I've owned it.
I looked at my Haynes manual and it says every 3 months or 3,000 miles whichever first.
I've been using 5w20 penzoil conventional when they have it, and supertech 5w20 conventional the other times. Which interval should I stick to? I hope to get 275k+ miles out of this car
Re: Oil change interval?
That recommendation is probably using conventional, because that’s all conventional could do at the time. I always did 3,000 miles because it’s 5,000km for me and it’s a nice rounded off number. I also use synthetic so it’s barely broken on when I change it lol. If the oil looks good when you drain or, I doubt I’d change anything.
I was surprised to find the '05 owner's manual says 10k miles for oil changes, 5k miles for severe conditions. I would do 5k miles if using conventional oil, I currently do 10k intervals on synthetic oil.
Surprisingly the owners manual for 2004 civics says to replace every 10,000 miles or 1 year for normal operating conditions. Or 5,000 miles or 6 months for severe conditions.
I've been using conventional since I want to keep things consistent. And this car only sees like 2000 miles of use every 6 months. Would switching to synthetic cause any issues with old seals on the car?
So my local walmart supercenter stopped carrying conventional oil altogether. I'm switching to supertech full synthetic 5w20 for engines over 75,000 miles. The oil filter I got is rated for 20,000 miles.
Should I replace oil every 10,000 miles 1 year or keep doing 5,000 miles or 6 months? And should I keep the oil filter for 2-4 changes?
I have never seen the point of keeping the filter on for more than one oil change. And I would stick to 5k, just make sure to check your oil level
If you often drive at low speed, you can change the oil in advance as much as possible, you’d better shorten the oil replacement mileage by 20%-30%. Shortening the replacement mileage, you can clean the carbon deposits and ensure the engine's normal operation.
Solid idea, i feel this is a good idea since cleaner oil at low stop and go speeds will ensure that piston oil rings won't gunk up. Even better with synthetic oil during cold starts.
cybernike
Feb 9, 2009 02:07 PM
bartolo5
19
Jul 11, 2004 03:50 PM
