Regular Maintenance Post Questions/Information about Regular Maintenance here
Blinking "Maintenance Required" light
Old Dec 28, 2014
G_ROBB89's Avatar
G_ROBB89 is an unknown quantity at this point
Hello All,
At around 105K miles my '04 Ex's "Maintenance Required" light began flashing at power up. The light will flash 10 times and go out.
I am wondering if this may be a result of some kind of preset that goes of as a reminder for routine maintenance when a certain mileage is reached, or if there may be some real problem?
Please let me know what you think.
Old Dec 28, 2014
Re: Blinking "Maintenance Required" light
Mileage counter. Oil change reminder. Either you are due, past due, or the last person to change oil didn't reset it.
Explained in your owners manual.
Key off
Push odometer reset button
Turn key on
Continue holding the reset button down until the light quits flashing. (about 10 sec)
Done.
Old Dec 29, 2014
CraigW's Avatar
You are in the area of the required timing belt, and some other parts maintenance please be aware.
Old Dec 29, 2014
mikey1's Avatar
i would say far overdue, by about 3 years
(if its never been done)
Old Dec 29, 2014
CraigW's Avatar
Forgot about the age factor. (7 years)
Old Dec 29, 2014
But OP's blinking maint idiot light is not on because of major services due.
It's only on because the car has gone something like 5000 miles (or whatever the actual number is) since the light was last reset.
Old Dec 30, 2014
mikey1's Avatar
yes i agree, sorry got off topic
Old May 23, 2020
Anthony Lopez's Avatar
Anthony Lopez is an unknown quantity at this point
I think something wrong with mine.
My maintenance light is on also.
Usually I have the key in the off position turn the key on
while holding the button down but light is still on when I turn the car on.
I don’t know if the push odometer reset broken is messing up. I never had such a hard time reset it. Because the shop I going to never reset it . One time I ask them how to. They didn’t how to reset it. I had to google it my self .
QUOTE=ezone;4676692]Mileage counter. Oil change reminder. Either you are due, past due, or the last person to change oil didn't reset it.
Key off
Turn key on
Done.[/QUOTE]
Old May 23, 2020
Colin42's Avatar
Well can you reset your trip meter?
Old May 23, 2020
Colin42's Avatar
And with the car totally off you need to hold the button down, turn the key to on (while still holding the button), dash will light up, maintenance light will blink once, and then keep holding until the light goes out
Old May 24, 2020
pretty common for the odo reset button to stop working.
Mine have not worked for like 10 years.
put a black tape on top of light
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
beveragemp
May 25, 2015 07:11 PM
Linda0818
Apr 23, 2015 11:30 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
blackbullet
Dec 1, 2001 03:44 PM
