PDA
View Full Version : I.C.E. (Audio) & Electrical Upgrades
Pages : [1] 2 3
  1. Direct Speaker replacements for front doors
  2. Honda civic 1996-2000
  3. 99 Civic reverse switch help
  4. Honda civic 1998 radio question...
  5. 96-98 Double Din conversion info...
  6. LED Headlight Bulbs
  7. Headlight Units
  8. LED Blinker Module
  9. What Speakers to Choose?
  10. LED plate lights for 2000 civic sedan...
  11. I need a cluster pin-out diagram for a 2000 ex sedan (building a custom cluster)
  12. Grommet next to battery! +Cig Adapt
  13. Bad Alternator?
  14. 1999 Civic LED recommendations?
  15. Wiper motor issue
  16. DIY remote start install?
  17. Need advice on power door locks
  18. Having trouble figuring out what amp alternator to get?
  19. Cannot defrost
  20. Idle p505
  21. Power Windows not going down & Brake Lights not coming on
  22. Fuse 15 Keeps Blowing
  23. 1999 civic key not staying in locked position to drive when starting,shuts off
  24. Blowing fuses
  25. Oil pressure light
  26. Integra 98 cluster
  27. Sweep delay rear window
  28. Obd 2 has power, no connection
  29. No Halos
  30. Will a 99 civic double din radio dash bezel fit in a 96 civic si
  31. Interior Console Cutomization
  32. Adding wiring for Dash Cam 2000 Civic LX
  33. A.c. controls 01 to 97 swap
  34. Charging problem please help?
  35. Pointers for adding a second battery?
  36. Weird electrical issues
  37. Tachometer not functioning/Vtec not crossing over
  38. 95 Honda civic electrical
  39. No spark
  40. Fuel gauge problem
  41. Instrument Panel Lights Not Working?
  42. Ek Civic coupe, chopped wiring issues
  43. OBD scanners
  44. Hear something clicking inside car
  45. Can someone measure their current on IG1 while off?
  46. Stock Rear Audio Crossover?
  47. Wont turn over (good starter & new cables)
  48. My Stock Deck Threw a Code "CDE-01"
  49. Driver side Door lock
  50. Intermittent speaker and tweeter buzz, driver door
  51. HELP! auto door lock problem 98 manual civic
  52. 99 civic no spark after coil help.
  53. Door lock wont work
  54. Defroster wire detached from window.
  55. 2005 EX cd changer gone bad
  56. Side Speaker Installation [SOLVED]
  57. 99 civic intermitantly stalls
  58. Parking light troubles
  59. 97 coupe window issue
  60. Push start
  61. How can you take the whole power outlet out wires and all ?
  62. Chime not working right
  63. 1999 EX V-Tech Swap to 1998 Dx Body
  64. Civic 2000, left front blinker sometimes doesn't work
  65. Passenger window not working on 98 civic ex coupe
  66. eld code on 97 civic d16y8
  67. Help!
  68. Converting manual a/c climate control to electric
  69. mode motor defrost air vent controls
  70. Electric locks draining battery?
  71. Instrument light dimmer?
  72. Changing Climate Control Lights
  73. 99 civic door locks
  74. Add Audio Jack for Phone, iPad etc...
  75. 1997 Honda Civic LX P0700 code
  76. Need Help Running Wires!!!
  77. Where to Find Heater Control Panel Connector Pinouts?
  78. Led Interior Help needed !
  79. Common aftermarket fog light kits
  80. Alternator overcharging
  81. Auto dimming rear view mirror diy help pls
  82. Voltage at AC Pressure Switch?
  83. Battery Light
  84. Help! What are these things? Yellow wire cut? PICS
  85. 98 civic ex electrical problems
  86. 96 Honda civic Power window issue
  87. 2000 DX Sedan engine coolant sensor
  88. Two Tone or Colour Contrast Ideas **
  89. 97 HondaCivicDX - computer or no?
  90. single LED per bulb license plate light upgrade?
  91. no power door locks
  92. need some help with obd port for live data
  93. starting issue
  94. Map Lights in 99 Civic LX
  95. 97 Coupe, key won't turn ignition.
  96. 99 civic hatchback headlight issues
  97. Install Viper 5204v on 98 civic ex, car wont start
  98. 98 civic Y8 IAC wires on pin outs
  99. 1996 civic electrical problems
  100. LED Dome Light Panel
  101. 98 DX Guage cluster
  102. Door mirrors not working
  103. differences in floor harness years
  104. How-to for Si floor harness
  105. ECU head scratcher
  106. 1999 Civic SI power window problem.
  107. Dash lights turn off when headlights turn on. **SOLVED**
  108. em1 coupe access to wires
  109. Gas gauge rises to full mark.
  110. O2 simulator
  111. 98 Civic Ex alternator + ECU
  112. Speaker issue (Wiring/Weather Proofing issue)
  113. 2 alternators
  114. 99' civic wont start..
  115. car goes dead and wont restart
  116. Radio and lighter electrical
  117. honda civic 1997 lx wont start . eld problem?
  118. 98 lx stock keyless entry head unit hidden in dash
  119. Bad Connection? Unknown issues
  120. Flickering Lights/ Electronic Issues - Post Audio Install Help
  121. 2000 Honda Civic EX Cassette Player has no power
  122. Alarm causing problems!
  123. wires on bumper assembly
  124. Install Ddin hu and 4speakers 00ex coupe
  125. Installed new head unit, and now parking lights won't turn off
  126. First time doing large audio install.
  127. 97 Civic LX back up lights not working
  128. Which is the right MES connector to reset SRS on Civic 2000 EX?
  129. defrost
  130. 2000 Civic LX Alternator
  131. Need a more comfortable seat
  132. gauge cluster backlighting intermittent....
  133. Possible bad alternator and a brake light question
  134. Upgrading to variable speed intermittent wipers
  135. car door keeps clicking
  136. Civic will not start!!
  137. How do you ground the trunk light of a '98 honda civic coupe?
  138. cluster lights reversed
  139. Driver side brake light always stays lit.
  140. Installing stereo
  141. power lock switch not working!!
  142. 2002 Civic LX- OEM Keyless Entry Install
  143. Tail Light Help
  144. Anyone try installing a bigger battery on stock tray?
  145. Possible Ignition Coil?
  146. Stupid electrical question
  147. Need help bad!!
  148. interior dome light does not work
  149. 1996 Gauge Question!
  150. !!Amplifier help!!
  151. knock senor female insert
  152. 98 civic radio replacement
  153. FI EM fuse keeps blowing...
  154. Any good alarm systems ?
  155. replacing stock radio on 98 ex civic coupe
  156. Replacing OE radio harness
  157. what hid kit do i need to get for my car ?
  158. Cat system and o2 sensors
  159. Front Speaker wiring
  160. Front Turn signal bulb access'98 DX
  161. Best place to buy fog lights?
  162. foglight hook up
  163. Civic EX coupe power window/locks problemHELP
  164. Christmas Help, PLEASE! :/
  165. New Stereo set up - Please Advise
  166. Sony Xplod Settings
  167. Just power door locks?
  168. Possible Tweeter locations with Pictures?
  169. vtec light help
  170. Amplifier question
  171. Is my factory wiring inadequate for my Rockford Fosgate speakers?
  172. Newbie needs help
  173. Drivers side light
  174. Dome Light Issue
  175. Sub-par sound quality.
  176. Lock Problem
  177. srs fuse# 23 and srs/fuel pump fuse#13 keeps blowing
  178. Headlight Assembly Installation (96 civic)
  179. 98 civic ex cable reel help
  180. 99 Civic EX Interior Fans Not Working At Any Speed
  181. 2000 Civic SE, removed distributor but forgot to mark it
  182. Need help building a sound system
  183. Wiring Spoiler Lip To Brake Lights?
  184. Check engine light
  185. What do I need to install this stereo?
  186. review my future set up please
  187. Keyless Entry Problem
  188. Civic 99 EX - OBD 3-pin Conn capabilities
  189. computer programing ?
  190. Gauge Cluster Help!
  191. 1998 Civic LX randomly dying (ignition problem?)
  192. Unstable electric power
  193. when i turn my headlights on my stereo turns off then back on.
  194. LED Dome Lighting
  195. Pioneer Head Unit Install help
  196. Need to run 12v directly from my under-dash fusebox. (2000 Civic DX Hatch)
  197. Civic 98 trans. lights
  198. 2000 civic ex DIN kit
  199. Installing a single power door into my 2000 DX
  200. car losing power (updated 8-18-12)
  201. Should I get a capacitor?
  202. Electrical problems "NEED HELP"
  203. 98 civic speedometer going crazy!!!
  204. Car alarm/car security, I must improve mine!
  205. having problems keeping my volts up for my stereo system
  206. D16Y8 wiring problems
  207. (LEDs)Experts please help us
  208. New home for my battery
  209. Helppp
  210. Electrical Techs - 97 Civic Electric Door Locks Quit Working
  211. Electrical Techs - 97 Civic Electric Door Locks Quit Working
  212. a different locking problem
  213. no signals
  214. scattered info (want to replace speedo bulbs)
  215. After Market Fog Light Question
  216. Equalizer Dash-Kit?
  217. speed sensor location???
  218. Bench test a TPS?
  219. dome light & door lock problem
  220. Heat not working
  221. Help?
  222. 99 EX Auto - Gauge illumination
  223. front door speaker
  224. Nuts for battery terminals?
  225. 96 Electrical Gremlins
  226. N E E D help choosing fog light color!
  227. Ebay fog light help
  228. Oxigen sensor
  229. Alarm is Triggering Ignition Lockdown
  230. Problems with Intellistart 4. Car turns over then immediately dies.
  231. Cluster Gauge problems
  232. Differing RMS ratings and Amps?
  233. 2000 Coupe EX Rear Deck and Speakers
  234. Using dielectric grease and anti-seize on spark plugs
  235. honda oem door lock actuator help
  236. Hi beams & Low Beams Simultaneously
  237. Anyone add factory cruise control to a 99 VP?
  238. power mirrors not working
  239. Front Speaker Next Step
  240. cant seem to find any ecu service connectors here in my area...
  241. wiring for a apexi neo
  242. High beam indicator goes on when headlights are on
  243. Lights won't turn on
  244. 2000 civic stock speakers
  245. power windows
  246. Aftermarket Deck install help?
  247. Heated Mirror Problem
  248. CKF Wire eaten by belt HELP!
  249. ignition tumbler replacement help!!!
  250. My SRS light stays on!
